Toyota Truck & 4runner Parts "anything U Need"
#364
2004 'runner part needed
my 2WD '04 left front abs sensor needs the wire harness that runs from wheel to computer. I checked and got no continuity in my old one, and am showing L front sensor failure. Replaced sensor, but I think wire is bad, if all it does is provide continuity to computer from sensor plug. I check the two-line wire and got no readings for continuity. I think this wire is common for a number of years, and possibly other Toyotas, although the mounting brackets may be different. Thanks
#365
Would you happen to have a fuel pump bracket for a 94 pickup 3vze? I have talked to everyone and the only place I can find it is at the dealership and they want the big $$$ for it.. I just need the bracket i have everything else. Pleast PM me whenever possible if you do
#374
ecu?
Looking for an ECU from a 91 or 92 4wd pu or 92 runner. The PO of my truck put one from an 89 in the truck and now I don't have a speedo.
Need the ecu and part of the wiring harness. Part number is 89661-35630. Thx
