Tacoma ARB & ORS manual hubs in Az
Old May 3, 2007 | 08:17 PM
Mark in Az's Avatar
Tacoma ORS manual hubs in Az
Parts from a 2001 Tacoma with 50,000 miles
Here's the pics:
http://good-times.webshots.com/album/558741740lYPfjv
Everything is OBO and prefer local pickup in Chandler, Az
Front IFS diff with 4.88 Yukon gears and ARB locker $700 SOLD
Includes an aftermarket air filter/pressure regulator, ARB dash switch, ARB solenoid, all wiring and airline tubing. You will need an air source such as a compressor or CO2 tank.
Approx. 30000 miles and never had any problems with this locker.
(Probably more like 300 miles since it had manual hubs)
http://www.drivetrainspecialists.com...duct-2372.html
The ARB RD90 is about $700 new and the gears are about $200 (plus installation)
Front Manual Hub Conversion on ABS spindles, two axles and one spare. Was $650 REDUCED $550
Approx. 30000 miles on this Off Road Solutions manual hub conversion.
This includes everything in the $1049 ORS kit # ORS-HB001 shown here:
http://www.offroadsolutions.com/prod...conversion.htm
http://www.4x4wire.com/toyota/review...ub_conversion/
plus one spare axle assembly and both ABS spindles with the wheel bearings installed. This spare axle was never installed, but was made from a used IFS axle using an ORS outer and ORS hardened shaft that cost about $115. If you want to use this on a non-ABS truck you'll need to cap the ABS sensor holes in the spindles; those caps run about $12 a pair. You'll also then need to install stock ball joints.
All Pro # 3500T-AP-A-ARM shown here:
http://www.allprooffroad.com/index.p...ask=view&id=95
Buy the UCA for $200. SOLD
All Pro rear leaf springs 4500T-AP-PR $150 SOLD $100
Approx. 20000 miles. Great springs made by Betts. Includes new bushings.
http://www.allprooffroad.com/index.p...ask=view&id=96
Sway-A-Way 2.0 Coilovers $300 SOLD
Approx. 40000 miles. Tundra valved, 15" 650lb coils, new bushings, spanner wrench. I ran these until I cut off the front suspension. Original, un-rebuilt, 2.0 coilovers that you'll need a winch and bumper to compress. Never had any issues with these other than they are stiff to be able to hold up a heavy front end.
Steering Rack with urethane bushings $100 SOLD
Stock lower control arms $50/pair
Stock upper control arms $50/pair
Approx. 20000 miles
Stock calipers and rotors $100
Pads have a couple thousand miles on the Raybestos ceramics. The rotors were never turned, they measure 22mm on a 20mm minimum thickness, and are smooth but have some discoloration from the ceramic pads.
Last edited by Mark in Az; Jul 16, 2007 at 06:45 PM. Reason: New price for ORS stuff
Old May 3, 2007 | 09:42 PM
toy_tek's Avatar
If the front IFS diff fits a 97 4Runner, I'd like first dibs. PM sent.
Old May 4, 2007 | 05:10 PM
Mark in Az's Avatar
Ok, Jon's first
Old May 6, 2007 | 10:31 AM
p1michaud's Avatar
Question Coil overs
Mark,
I may be interested in your coil overs. How long have you owned thes? Do you think they need to be re-built before use? Any excessive wear, squeeks, noise, etc...
I wonder how much $ re-building these would cost. By the way, shipping would be to 04619, how much?
Cheers,
P
Old May 6, 2007 | 07:58 PM
Mark in Az's Avatar
I'm waiting to hear from someone who's interested in the coilovers...I'll let you know what happens.
I bought them from Camburg in Aug '01. SAW rebuilt them and added the Tundra valving in May '02. I've run them ever since without recharging or rebuilding. There weren't any issues with them when I took them off...they don't leak or squeek
Here's Chris' excellent article on rebuilding 2.0 SAWs:
http://www.bajataco.com/sawrebuild1.html
Old May 6, 2007 | 09:12 PM
toy_tek's Avatar
Mark - Busy day didn't go as planned. Will be in touch hopefully monday afternoon.
Old May 6, 2007 | 11:34 PM
d0ubledown's Avatar
hmm..your uca's are tempting. were they a bitch to align after? and does it come with the uniball or ball joint?
Old May 7, 2007 | 07:00 PM
Mark in Az's Avatar
Nope, no problems with alignment and they come with uniballs, but All Pro doesn't show that they'll work on 4Runners
Old May 11, 2007 | 03:38 AM
p1michaud's Avatar
Question Front Diff
Mark,
Did the front diff sell? I'm interested but you would have to ship to 04619.
Cheers ,
P
Old May 11, 2007 | 06:37 AM
Mark in Az's Avatar
Originally Posted by p1michaud
Mark,
Cheers ,
P
Hi Pierre,
I'm still waiting to hear from people on the coilovers and the diff. I'll send you a PM.
Old May 11, 2007 | 07:29 AM
Albuquerque Jim's Avatar
Mark, I have a friend interested in the diff...he can do it today
Old May 11, 2007 | 08:12 AM
Mark in Az's Avatar
Willing to pick up and has cash in hand
Diff is SOLD!
Thanks Jim (and thank your friend for me)
Old May 11, 2007 | 08:58 AM
Thanks Mark, Paypal sent!
Old May 25, 2007 | 07:32 AM
Mark in Az's Avatar
ttt
Open to offers.......
those ABS manual hubs aren't doing any good sitting in the garage!
Old May 28, 2007 | 04:19 PM
spinemup's Avatar
id like to make you an offer on the rear springs... please email me.
Old May 30, 2007 | 08:19 PM
jumbominitaco's Avatar
do you still have the brakes?
Old May 30, 2007 | 09:57 PM
Mark in Az's Avatar
Yes, still have the brake stuff
Old Jun 5, 2007 | 06:40 AM
Mark in Az's Avatar
Rear Springs are sold.
Still have the manual hub stuff & ready to move it
Old Jun 7, 2007 | 10:41 PM
Hornito's Avatar
pm sent on uca's.
Old Jun 10, 2007 | 11:07 AM
apalmer1's Avatar
PM sent
