Parting Out - 2004 Toyota Tacoma V6 4x4 Extended Cab
Old Apr 29, 2006 | 03:38 PM
pwscottiv's Avatar
I'm parting out my entire truck. FYI: I have long-standing profiles up at TTORA and Customs Tacos, but I'm a NewB here...
Website: http://www.scott-industries.com/4sale.html
Pictures (over 100): http://www.scott-industries.com/4sal...ndex/index.htm
Modified Toyota Parts List: http://www.scott-industries.com/4sal...acomaParts.pdf
PLEASE READ THIS FIRST!
To keep things fair and organized, I'd like to set a few guidelines.
1. I'd rather people on this forum contact me in this thread (not email or PM). My reasoning for this is to keep things "1st come 1st served" (so nobody gets mad)
2. In an attempt to keep my pricing competitive and fair, I'm getting my pricing information via the Toyota Dealer Parts Catalog that's listed on my website. I'm adjusting the prices between 20% and 80% off, most parts landing about 50% off. If you find that a part price in the catalog is incorrect (i.e. Your Toyota dealer sells it for less), then by all means please let me know and I'll adjust my pricing accordingly (I will confirm the price with that dealer.) Yes, online original Toyota parts dealers are ok too.
3. Please check to see if I've already quoted someone a price for what you want. If they haven't claimed it as theirs for that price within 48 hours the next person in line can ask me (on the thread) if they can claim it.
Thanks
FYI: I'll be quoting my prices as follows to make my quotes easier to find. Ex:
Item --- Dealer's Cost --- Your Cost
Skidplates --- $320 --- $60
Please search to see if I've already quoted someone for the part you want.
Pictures of almost every component and a Modified 2004 Toyota Parts List can be found here: http://www.scott-industries.com/4sale.html
Available components:
Most of the items for sale are listed here and/or shown in the pictures.
- TRD Headers W/Ceramic Coating --- $950 + $225 = $1175 --- $800
- TRD Exhaust (Modified)--- $700 + ? --- $350
- Rear Passenger Fender Flare --- $220 --- $85
- Shift Boot (with metal plate)--- $88 --- $45
- 4x4 Shift Knob --- 60% Off Retail
- A/C Evap. --- $360 --- $150
- Instrument Cluster --- $1275 --- $350
- Center Cluster Finisher --- $100 --- $50 (When I don't need it anymore)
- ECU --- $1000 --- $500
- Sport Bucket Seats --- ~$1200 each --- $325 each or $590 for both
- Passenger Threshold/Sill Plate --- $90 each --- $35 each
- Third Brake Light Cover --- $75 --- $30
- Window Washer Pump --- $60 --- $30
- Blower Assy --- $455 --- $225
- CV Axles --- $370 each --- $250 each
- Airbag Switch --- $165 --- $65
- Steering Column Assy --- ~$1100 --- $350
- Steering Yoke --- $260 --- $120
- Outer Boot --- $75 --- $30
- Upper Column Cover --- $60 --- $25
- Lower Column Cover --- $45 --- $20
- Power Steering Rack --- $930 --- $450
- Upper Control Arm --- $205 each--- $100 each
- Lower Control Arm --- $315 each--- $150 each
- Knuckle/Spindle Assembly --- $415 each --- $200 each
- Tie Rod Ends --- $55 each--- $25 each
- Power Door Locks --- $250 each --- $125 each
- Front Console Assy. --- $70 --- $35
- Stabilizer Bar Link --- $45 each --- $20 each
- Rear Mudflap w/Bracket (passenger only) --- $105 --- $40
- Engine Compartment Wiring --- $? --- $250
- Cab Wiring --- ~$3000 --- $600
- Rear Wiring --- $? --- $150
- CD/Cass/Radio --- $415--- $150
- ABS Control Unit --- $415.75 --- $150
- Rear Bumper --- $312.00 --- $145
- 4WD Computer --- $267.92 --- $125
- TRD Locking Differential Computer --- $250 --- $125
- Passenger Sun Visor --- $67.45 --- $30
- Driver Sun Visor --- $58.33 --- $25
- Fuel Tank --- $411 --- $125
- Fuel Pump Base W/gasket --- $45 --- $20
- Fuel Level Sender --- $120 --- $60
- Fuel Pump --- $270 --- $130
- Fuel Tank Strap Assy --- $55 --- $25
- Fuel Tank Protector w/ bracket --- $375 --- $130
- Spare Wheel Hanger (4x4) --- $169.45 --- $69
- Inner TieRod End --- $137 each --- $60 each
- Door Locks --- $250 each --- $90 each
- Side Window Latch w/Hardware --- $40 --- $17
- Glove Box --- $140 --- $65
- Instrument Cluster Bezel --- $90 --- $45
- Clock --- $230 --- $65
- Glass Run (WeatherStrip) (Drivers side only)--- $95 --- $45
- Door Opening WeatherStrip --- $75 each--- $35 each
- Cowl Trim Panel (passenger only) --- $45 --- $20
- Exterior Door Handle - Passenger (Lock Cylinder Not Incl)--$81 --$35
- Windows (Drivers Side, Passenger Side, Rear Passenger Side)
- Anti-Lock Brake (ABS) System
- Fuse Boxes (engine compartment and cab)
- Fuel and EGR Lines
- Rear Catalytic Converter
- Fuel Tank
- Front Brake Calipers
- Intake Manifold and Plenum
- Interior plastic components (Center Console, Dash Sub-Components, Instrument Cluster, Steering Column, etc)
- All Door and Window Seals
- All Suspension Components (Rear Leaf Springs, TRD Shocks, Upper/Lower Control Arms, Steering Rack, Anti-Sway Bar, etc)
- Tires/Wheels
- Complete Air Conditioning / Heating System
- Windshield Washer Pump and Level Sensor
- Bolts
- Rear Bumper
- Complete Lock Set w/Keys
Unavailable components:
If an item is in the "Unavailable" list I definitely don’t have it.
- All Sheetmetal
- Gas Tank Filler Tube
- Tail Lights
- Windshield Washer Tank
- Cab Mounts W/bolts
- A/C Condenser (Radiator)
- Radiator
- Dash Light Dimmer
- Tailgate
- Seatbelts: Front Passenger
- Frame (fully intact with all crossmembers)
- Front Bumper
- Windshield
- Main Dashboard Component (Sub Components available)
- Air Filter Box
- Small Rear Drivers Side Window
- Headliner
- Drivers side "Lock Pillar Trim"
- A-Pillars Plastic (passenger)
- Rear View Mirror Casting
- Front Grille Assembly
- Light Dimmer
- Frame/Chassis
- Passenger Seatbelt
- Radiator
- A/C Condenser
- Stock Body Pucks with Bolts
- Passenger Turn Signal
- Altezza Tail Lights
- Tailgate
- Carpet Kit
- Power Window Motors
- Door Control Panels (Driver)
- Door Control Panels (Pass.)
- Drivers Side Mud Flap
- Carpet Kit
- Drivers Side Door Seal
- Gas Door Assy
- Horns
- Drivers Side Cowl Trim Panel
- Engine Fan
- Rear Window W/Slider
- Rear Window Seal
- Wiper Arm Assembly
- Front Shocks w/springs
- Rear Shocks
- Jack w/kit
- Jack Retainer
- Cable Stays
- Driver Airbag Module
- Passenger Airbag Module
- Spiral Cable (Airbag)
- Airbag Control Unit
- Airbag Sensors
- Headlights
- Passenger Airbag Cover
- Fuel Level Sensor
- Skidplates
- Side Mirrors
- Ashtray Assy
- Skid Plates
- Leaf Spring Shackles
-5VZFE 3.4L V6 Engine (10k Mi.)
-All Engine Sub-Components (Alternator, Power Steering Pump, Starter, AC Compressor, Wiring Harness)
-All Driveline Components (Front/Rear Differentials, Drive Shafts, Manual Transmission, Transfer Case)
- Driver door seal
- Passenger window seals
- A/C Heater Control Assy
- Hazard Light Button
- TRD Supercharger Kit
- 7th Injector Kit
- Master Brake Cyl Assy.
- Brake Booster
- Rear Back Rest
- Back Rest Trim
- Rear Seatbelt Retainer
- Rear Belts with buckles and covers
- Drivers Belt with buckles and covers
- Leaf Springs
- Husky Truck Box
Old May 1, 2006 | 01:11 PM
pwscottiv's Avatar
The Side Trim Panel Assy, Upper Column Cover, and Lower Column Cover have been SOLD.
Old May 1, 2006 | 04:39 PM
pwscottiv's Avatar
The Supercharger, 7th Injector Kit, and Boost Gauge have been sold.
pwscottiv's Avatar
The Master Cylinder and Brake Booster have been SOLD.
Old May 1, 2006 | 04:51 PM
pwscottiv's Avatar
The following items have been SOLD:
- Rear Back Rest Cushion
- Back Rest Panel
- Back Rest Trim
- Rear Seat (Driver)
- Rear Seat (Passenger)
- Side Trim Panel Assy
- Cup Holder Assy
Old May 1, 2006 | 10:07 PM
ianshoots's Avatar
Whats your location? Are the wheels still around?
Old May 1, 2006 | 10:32 PM
pwscottiv's Avatar
I'm in El Dorado Hills, CA (Near Sacramento). Yes, I have two sets:
Set 1 (very good condition, but only has 3 wheels/tires):
16x7" Alloy Wheel W/Center Cap and Stock Tire:
Dealer Cost: $425 each = $1275 total
Asking Price: $140 each or All 3 for $320 Total
Set 2 (some visible corrosion, but no mechanical damage):
Dealer Cost: $425 each = $1700 total
Asking Price: $125 each or All 4 for $350 Total
Old May 14, 2006 | 07:52 PM
crappled's Avatar
You have a picture of the gastank skid? details?
Old May 14, 2006 | 09:58 PM
pwscottiv's Avatar
Hey,
Pictures can be found here:
The skid is in excellent condition. As I can recall it has no dings and very few minor scratches.
If you're interested I can take more pictures...
Old May 15, 2006 | 08:04 AM
crappled's Avatar
That's fine, I just saw ALL skids were sold? Price shipped to 45424? PM if you want.
Old May 15, 2006 | 11:01 AM
pwscottiv's Avatar
Just the front skids were sold... I'll quote you shipping once you agree to purchase it.
Old May 15, 2006 | 06:45 PM
JerryD's Avatar
How much for the rear leaf springs shipped to 63755?
Old May 15, 2006 | 07:05 PM
pwscottiv's Avatar
I already sold the springs that are pictured, but I have another set that I'm selling from my current truck. They have a little corrosion on them, but not too bad. Toyota's price is over $1000 for the pair. I sold my last set for $500 for the pair. I'll sell these for $325 for the pair. I'll need to calculate the shipping after I get them off my truck (this week). Let me know if you're interested. Thanks
Old May 15, 2006 | 10:39 PM
crappled's Avatar
I can get a custom one for about that. Thanks and GL.
Old May 16, 2006 | 06:43 AM
JerryD's Avatar
Thanks anyway, I can get some aftermarket ones that price.
Old May 30, 2006 | 03:46 PM
zmacman's Avatar
Are the power door lock assemblies still available? Would you or anyone happen to know if they would plug right into a 98 Tacoma extended cab? What is the best price?
Old Jul 17, 2006 | 10:55 AM
BOSTON4RUNNER's Avatar
I am interested in the charcoal EVAP with valves...
Old Aug 4, 2006 | 05:21 PM
98TOY's Avatar
Instrument Cluster
Is the instrument cluster still available?
EDIT: Need the I.C. housing too.
Old Aug 4, 2006 | 07:08 PM
pwscottiv's Avatar
Yes, it's still available. I.C. Housing?
Old Aug 4, 2006 | 08:03 PM
bosco's Avatar
So do you have any experience working at a junk yard? Cause your prices reflect that of a high end yard! I am bored so I added up all the prices you have listed. I could buy a very nice complete running truck for what you are selling all of your parts for!!! Dont mean to hijack, just bored. Good luck though!
Oh and the total I came up with was $8,806.00! And thats just the prices you listed! I wish I had that much to sell!!!
