Parting 88 3vze V6
Old Feb 15, 2008 | 10:15 PM
Adam F's Avatar
Originally Posted by Adam F
Parting engine only, not the whole truck
Old Feb 22, 2008 | 02:32 PM
4x4phil's Avatar
I would like the cold start injector, the timming switch that goes to the cold start injector
Old Feb 22, 2008 | 03:55 PM
Adam F's Avatar
How does $30 shipped sound?
Old Mar 2, 2008 | 06:27 AM
Jim B's Avatar
Bump for adam. This engine is in great condition. I bought the heads off this engine but found out i had a rod going bad and could not use them. the heads were in good condition and a very nice honey color. This is a very well maintained engine.
Old Mar 2, 2008 | 07:05 AM
  #25
Aaronn's Avatar
looking for the alternator brackets ..do you still have them ?
Old Mar 4, 2008 | 07:38 AM
  #26
Kiwipushrod's Avatar
Dude,
Welcome to Yodatech!
Try searching, Marlincrawler, they may have some info for Your trans.
Thanks Kiwi
Old Mar 4, 2008 | 11:32 AM
  #27
Adam F's Avatar
Yes I do. PM me with a price.
Old Mar 4, 2008 | 11:35 AM
  #28
Adam F's Avatar
Old Mar 4, 2008 | 01:47 PM
  #29
Adam F's Avatar
Old Mar 7, 2008 | 06:02 PM
  #30
Adam F's Avatar
AFM, ECU, fuel pump, fuel rails, and power steering pump have been sold.
Sale on engine block is pending
Old Apr 14, 2008 | 02:20 PM
  #31
Adam F's Avatar
Parts that are still available:
Fuel injectors and fuel rails
Upper and lower intake manifold
A/C compressor
A/C condenser
A/C cooling unit (black box under dash...has evaporator, etc)
Air box minus AFM
Fan clutch and fan (shroud is gone)
Ignitor and coil (I think I have 2)
Distributor
Cold start injector and timer
ECU temp sender
Upper timing belt cover
Old Apr 18, 2008 | 10:11 PM
  #32
jeopardy98's Avatar
I'm clueless but I have a 95 pickup without A/C. Would your parts allow me to have A/C? Does it work that way? I don't even know if I have lines run. Do they run the lines on all of them? If it would work I might be interested in that stuff.
Old Apr 19, 2008 | 01:19 AM
  #33
Adam F's Avatar
Your 95 is a different body style than my 88, so chances are it wouldnt work. If it were a 88, then yes it should be a direct swap.
Old May 13, 2008 | 05:28 PM
  #34
ScottyC's Avatar
Distributor
ECU temp sender
I will take these. Do you still have the ECU though? Was it for a manual tranny?
Old May 26, 2008 | 09:32 PM
  #35
mem5922's Avatar
Need A/C stuff
Adam,
I am looking to add A/C to my 89 2WD xcab 3VZE for the upcoming (hot) summer here in So California. I've only had the truck 3yrs and do not know what parts I need to collect to add the A/C option. Do you have what I need or do I need more parts than the 3 A/C parts you listed. Thanks. -Mike
Most parts have been sold. Here is what's left
fuel injectors and fuel rails
A/C compressor
A/C condenser
Air box minus AFM
Distributor
ECU temp sender
Old May 27, 2008 | 09:27 AM
  #36
galloway's Avatar
ok how much for a c- rod and piston.
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
akaphilly
Jul 9, 2015 02:34 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
