JDM Surf Electric/Digital Compass and Fender Mirror!
Old Mar 20, 2006 | 04:38 PM
theREALjdmSURF's Avatar
I just wanted to make sure that everyone knew this was out for sale and fully functional...
Old Mar 20, 2006 | 05:04 PM
midiwall's Avatar
(shhhhhhhhhhhh... we're all waiting to snipe on each other at the end of the auction!)
Old Mar 20, 2006 | 06:19 PM
sswearin1's Avatar
what he said!
Old Mar 20, 2006 | 07:10 PM
arjan's Avatar
You guys don't need that, you can't even read celcius. You have to live in Canada to be eligible to bid on this
Old Mar 20, 2006 | 10:13 PM
  #25
midiwall's Avatar
peh! for a mere pitance I'll find myself a C->F calculator that I can duct tape to the windshield!
Old Mar 21, 2006 | 01:38 AM
  #26
surf4runner's Avatar
b vewry vewry qwiet, were out bidding each other
Old Mar 21, 2006 | 05:59 AM
  #27
arjan's Avatar
That will make for a clean install
I would like this thing, but I don't have a sunroof. I am hoping a non sunroof version will be auctioned one of these days.
Old Mar 21, 2006 | 06:10 AM
  #28
midiwall's Avatar
Put one in!
https://www.yotatech.com/forums/f123/installing-sunroof-cut-waay-big-hole-what-now-76877/
Old Mar 21, 2006 | 06:20 AM
  #29
arjan's Avatar
That was a funny thread, I would need to install the roofliner which comes with the sunroof. It's almost easier to buy a different 4Runner with all the luxury from the factory.
Mine even has the manual windows and no AC. I do have power doorlocks and mirrors.
A sunroof would be out of place on this one
Old Mar 23, 2006 | 05:53 AM
  #30
I have to admit, you guys are a friendly bunch of rivals!!! Nice to deal with you all!!
Old Mar 24, 2006 | 07:50 AM
  #31
godspyro's Avatar
Good call, to bad it's not tan.
come on theREALjdmSURF
!!WE WANT MORE!!!
Old Mar 25, 2006 | 07:18 PM
  #32
midiwall's Avatar
woohoo!
I'll let folks know how it goes - it should be "interesting" to get running. And I think I have an idea about getting Mr. Fahrenheit to come to the party.
Old Mar 25, 2006 | 07:34 PM
  #33
arjan's Avatar
IT WAS YOU!!!
I tried to get it in the last minute, I was surprised how high you set your bid.
Congrats, hope it works out for you.
You think there is a circuit board switch for Fahrenheit or something along those lines? You can always just get used to Celcius, it's quite easy: 0C is freezing, 100C is boiling, but that's been discussed in the metric thread somewhere.
Post some pics once you get it in there.
Old Mar 26, 2006 | 03:32 AM
  #34
midiwall's Avatar
IT WAS YOU!!!
Actually, you don't know what my _max_ was - it only had to be a buck or two above your bid!
Oh, I'm okay with the conversion on the fly (Funrunner pointed out to me than an easy approximation for midscale is f = (c*2)+30) but I'll bet that Toyota didn't create their own ASIC to handle temp and humidity when there are plenty on the market that will do it for a VERY low piece price. If I'm right, _ALL_ of them have a pin that you can tie low (or sometimes high) that will flip the display to F.
You betcha'!
Old Mar 26, 2006 | 06:40 AM
  #35
arjan's Avatar
Google is you're friend, I've looked up several IC partnumbers and have had good luck figuring out what it does and what the pinouts are. I recently had one for steppermotor control, knowing the pinouts helps a bunch.
I had no idea I was bidding against you, I was surprised how low the amount was and put it what it was worth to me. I guess we where the only two interested in it, or daring enought to tackle the wiring.
Too bad you still a ways away, I have some 22 gauge 25 wire stranded control wire you're welcome to use. It is ideal for stuff like this.
I guess when you already have a sunroof, then you don't need many wires. I would bring the sunroof wires down also and was thinking to use the switch for lighting control or something like that.
Old Mar 26, 2006 | 10:08 AM
  #36
midiwall's Avatar
Google is your friend, I've looked up several IC partnumbers and have had good luck figuring out what it does and what the pinouts are. I recently had one for steppermotor control, knowing the pinouts helps a bunch.
Yeup... I'm an old hat at hardware hacking at various levels. My only concern will be if Toyota sanded off the lettering or otherwise rebranded the chip. Even so, there still aren't that many options and I should be able to figure out what they used by the PS and sensor connections.
!!! Yeah, I was at a friend's house, had to leave at the hour:30 point so I couldn't sit on it and hit it with 10 seconds to go like I normally do. You first hit at T-14, so we still would have probably been in this spot, 'cause you might not have had a chance to rebid after seeing me come in along side of you. But that would have only saved me $5...
I always find it fun to watch "prime" items like this come down to the wire. It interesting to see who's really on the auction and comes out of the woodwork.
Too bad you're still a ways away, I have some 22 gauge 25 wire stranded control wire you're welcome to use. It is ideal for stuff like this.
I'm set... I have a bunch of small gauge laying around. I'll have to get a feel for how much slack there is in the roof wiring, but I'm thinking that one of the first things I do is add a bit of length to those wires. And of course create a run for the external thermo and the spedo pickup. Heatshrink here I come!
Pin 10 at the diff lock huh? (thank you!)
I wonder what the snowflake is... I figure there's a moisture sensor somewhere, or maybe it's a combo of temp & pressure delta becoming an "ice" warning?
My interior is tan, so I'm thinking this will become flat black. We'll have to see how it looks once it gets here.
Old Mar 26, 2006 | 11:43 AM
  #37
arjan's Avatar
Snowflake comes on on most vehicles around freezing. Sort of an extra warning to watch out for black ice.
Here is the diagram I got the info from. I still had it on my hd from when I put the elocker in. I remembered that the locker doesn't engage over 5 km/hr or so, so I figured it must have a speed signal.
Old Mar 26, 2006 | 12:46 PM
  #38
marko3xl3's Avatar
I can't believe I missed this! But it sure was fun to see the summary of you two battling it out. Good read for sure.
So, when are more of these coming in? I know I would be very intersted, as would many others. I could care less if the temperature was in C, I come from Europe, but it would be real nice if someone could figure out how to display it in F. Does it even have a 3 digit display there?
Old Mar 27, 2006 | 07:28 AM
  #39
The display is 2 digits, only and the 'c' cannot be changed to 'f'. I was thinking that if you wanted to change the actual number readings, you could just do a tweak with the sensor (I've just started getting into IC's and making my own boards, so I'm not to familiar with these things yet...).
As I have already told a few peeps, I will be 'passively' looking around for more. I wasn't exactly impressed
with the way the auction went. I figured there would be a little more want
for it... If I can't locate one and pull one, myself, I don't think that even I could get it for that price....
I'll let you know if I get anymore, though. I'll be sending midi the wiring directions that I have along with the field monitor. I will be posting the same info here in the forums, somewhere, someday...... time is money (shhh...and I ain't got much of either....shhh)
Old Mar 27, 2006 | 08:43 AM
  #40
midiwall's Avatar
I have a question about this, especially since you mentioned the $$$ comment I made here on the forum in the auction itself (and I'm not sure how I feel about that).
If you wanted to get more for the unit, then why didn't you set a reserve? I think it's kindof odd, even a bit rude (to the buyer) to be complaining about what an item sold for when you didn't set anything in place to "protect" yourself from the bidding.
I'm sure you understand that the _perceived_ value of something is often different between buyer and seller. I've sold MANY pieces on eBay that went for a lot less than I had hoped. But, that's my fault for either not setting a reserve or having my expectations set too high. Either way, I've never gone back into a public forum and complained about what I got for the item.
I'm comfortable with what I paid for the cluster, and fwiw, it was under my max bid. I'm sorry if you were looking for more.
