Hayes brute clutch kit *new* - $125
Hayes brute clutch kit.
New. Never installed.
I made a mistake, I've got a 22RTE flywheel, which requires a bigger clutch.. My rotating assembly is already balanced and I can't use this.
"Clutch Kit, Organic, 1 1/8 in. Diameter Shaft, 21-Spline, 8.875 in. Diameter Disc, Toyota, 4Runner/Pickup, Kit"
"Hays Super-Brute clutch kits are intended for severe-duty usage, including such tough-on-equipment activities snow plowing and commercial towing. They're designed and manufactured with top-quality parts, featuring diaphragm-type pressure plates and clutch discs that have sprung hubs and organic linings. Kits come complete with pressure plate, clutch disc, throwout bearing, and clutch-alignment tool (most kits). Pilot bushing not included. "
"Engineered and built as a matched assembly, each kit will provide exceptional performance, durability and long term dependability. Each kit comes with; Performance pressure plate, clutch disc, throw-out bearing, clutch pilot alignment tool"
Comes in original box. with everything mentioned above.
It just went on sale at Jegs for $145 + shipping/handling. I'll ship it for free within the 48 states.
Should save you about $40 on a quality clutch that includes everything you need.. other than the pilot bearing.
Trade +/- cash for anything I can use on an 88 runner.
Ok.. someone make me a deal.... Doesn't do me any good with a 22RTE flywheel! I've got a spare pilot bearing also that I'll put in so it's 100% complete!
voiddweller
19
May 2, 2016 09:10 PM
