FS: 1992 P/U Reg Cab 22RE 5SPD, LIFTED/LOCKED
Old Oct 18, 2006 | 12:51 PM
AH64ID's Avatar
This is a fantastic rig, I get 18-21 mpg to and from work. It goes many many places. Its just not practical for me with a new daughter. I probably wouldn't use it like intended for too many years and don't have room for 3 rigs.
Drivetrain
22RE, 160,xxx miles
3-core HD radiator
HD PS Cooler, with Amsoil ATF
Amsoil everywhere (but engine due to TC replacement)
Centerforce Heavyweight flywheel
Centerforce DF Clutch
4.88's F&R, genuine gear (speedo is w/in 1%)
ARB rear air locker
Rear CV drive shaft
Warn Premium Hubs
Performance Mods
K&N Air Filter
LCE Ceramic Stainless 4:1 Header
Carsound hi-flow 2.25" cat
Flowmaster 60 series 2.25"
Custom 2.25? ?hi-clearance? exhaust
Larger 4runner IFS front Brakes
Suspension
Procomp Stage II 4" front
25mm HD Torsion Bars
Trail-Gear 56" 3" rear leaf springs
AllPro shackles ?? Lift
ORS /\ shock mount
RS9012 rear, RS90xx front
Rancho steering stabilizer
Protection
ARB Bull Bar w/ winch mount
Allpro HD sliders
Allpro HD rear bumper, 2 shackle mounts
1/4" aluminum skid plate
100 amp alternator, small pulley = 100 amps at 1500 rpm
Optima yellow top
rewired 12v plug, always hot
Rubber
5 x 35x12.50R15 BFG M/T (95% tread)
Do-Dads
ARB compressor with quick disconnect for airing up tires
Shifter mounted locker switch (from a diesel exhaust brake)
LED Shift light wired for locker
IPF Headlight Housings, H4 Conversion
Delta Champion tool box
Spare Parts
Front CV Axle
Air Filter for ARB pump
Front Sway-Bar, with quick disconnects, needs 3/8? spacer
NEW IN LAST 1000 MILES
Radiator, 3-core HD
PS Cooler, aux PS fluid was flushed
Fuel Filter
Fuel Injectors sonically cleaned and match flowed
Timing Chain
Head Gasket (Head shop said head and valves as good as new)
Centerforce HD Heavy Flywheel (increases inertia)
Centerforce Dual Friction Clutch, Throw Out bearing, Pilot bearing
LCE Ceramic Stainless 4:1 header
Carsound hi-flow 2.25 cat
Flowmaster 2.25? 60-series muffler
Wheel-bearings repacked
Starter rebuilt, professionally
asking $5000;
Old Dec 4, 2006 | 06:53 PM
Sonofmayhem's Avatar
interested in a partial trade for a 89 4runner? im buttoning up the new engine install this week.
Old Dec 4, 2006 | 06:57 PM
AH64ID's Avatar
Nope, I am selling it to get a 07 Taco... need a rig that can haul a kid, and a elk carcas, and dont want 3 rigs....
Old Dec 10, 2006 | 04:42 PM
yotakid825's Avatar
what about selling it without the motor?
Old Dec 10, 2006 | 11:34 PM
AH64ID's Avatar
Nope... only engine options are "as is" or repaired....
Old Dec 28, 2006 | 06:15 AM
BUNYKLR's Avatar
I'm interested for sure. I just need to find a buyer for my stock '89 ExtraCab. I may have one lined up as he's ready to get back into a Toyota after two unfullfilling years in an S10.
I'll be checking in periodically for status updates
Old Dec 28, 2006 | 06:18 AM
AH64ID's Avatar
So far nothing changed... proablly be all buttoned up with the motor and rear springs the first week or March...
Old Jan 1, 2007 | 11:11 PM
skoaq's Avatar
ah64id where did you get those frame sliders? would you be willing to sell seperate??
Old Jan 2, 2007 | 02:36 AM
AH64ID's Avatar
They are AllPros, and are welded on. I am not grinding them off...
Old Jan 26, 2007 | 04:54 PM
AH64ID's Avatar
Springs, and engine parts have arrived, now I just need to get home and install them.
Old Mar 1, 2007 | 02:00 PM
gilby4runner's Avatar
Old Apr 16, 2007 | 01:23 PM
jagger_snitt's Avatar
Is the asking price still $5000?
Old Apr 16, 2007 | 03:26 PM
AH64ID's Avatar
Yes, asking price is $5,000
Old Apr 17, 2007 | 07:39 PM
KevinInSac's Avatar
I wish you were closer... I really do.
Old Apr 18, 2007 | 04:18 AM
AH64ID's Avatar
its only 550 miles, that aint bad at all.... I have done 1100 mile days with a 22RE
Old Apr 21, 2007 | 12:31 PM
rivercat's Avatar
good luck lettin this one go.... i can vouch for Nala, she's been solid... hey John how did the 4:88's work out? i'm about to regear and i'm thinking the 5:29's might be a bit high for my 33's. i got the duals now so crawl ratio is not a worry, i still run 33's most of the time on the street and only run the 36's when we plan a weekend trip....
Old Apr 21, 2007 | 12:37 PM
Albuquerque Jim's Avatar
Please send pics to 20004runner (at) comcast.net
Edit: Never mind I followed the link...
Old Apr 21, 2007 | 01:15 PM
AH64ID's Avatar
Hey Rowan... When I ran 33's in there with the 4.88's it was all around great, needed to be lower on the trail.. but I guess you have that taken care of. I would still think about 5.29's... On the fwy on long trips you will really like them. I had to do a trip with 4.10's and 33's and 5th was used 3 times in 1000 miles, thou 3rd was faster up hills as you get 5mph or so more....
At 65 mph and 33's you would be 2860 (4.88) and 3100 (5.29), so not bad for 65mph and 33's.. With 36's you would be at 2560 (4.88) 2800 (5.29)... Knowing how Nala's motor runs U would prefer the 5.29's, she makes a big power increase at 2500...
Old Apr 22, 2007 | 05:44 PM
AH64ID's Avatar
Old Apr 30, 2007 | 02:29 PM
AH64ID's Avatar
more photos....
here you can see the 56" leafs, /\ Shock mount, flowmaster and hi-flow cat
