Complete 22RE EFI setup
Old Feb 4, 2007 | 07:02 PM
bkubisht's Avatar
I parted my way through an '86 4runner, and kept all efi stuff for myself. Decided to go with a different motor instead of converting to efi, so the EFI stuff is for sale. This should be everything but the fuel pump & tank needed for your conversion.
AFM, crossover tube, Plenum with all sensors, fuel rail, injectors, fuel filter, ECU, harness (uncut and labeled), throttle body, TPS, distributor, coil, igniter, etc. It's all there, and the plenum/injector/throttlebody assembly hasn't been disassembled.
$250 takes all! Will ship on your dime, located in Huntsville AL, or drive up to 50 miles to deliver for a $20 fuel surcharge. Would consider trade for low mileage W56, 8" aussie locker, or??? Ebay name is bkubisht, so you can verify that I have a good buying/selling history.
Old Feb 18, 2007 | 10:11 PM
YodaKrawler's Avatar
doyou have any pics?
Old Feb 19, 2007 | 12:30 PM
bkubisht's Avatar
I do think it's time I shot some pics. It takes up 2-3 big tubs. I'll post some very soon.
Old Feb 20, 2007 | 01:09 PM
navyredneck's Avatar
PM sent
Old Feb 25, 2007 | 01:24 PM
bkubisht's Avatar
I just took a bunch of pictures, and took inventory again since I moved from AZ to AL since packing everything up.
Bad news is I can't find the crossover tube. Shouldn't be a big deal though, many run a cone filter and move the battery to the driver side. And there's no O2 sensor, which I already knew but didn't specify.
I repacked into one big tub. Pictures and weight coming soon...
Old Feb 25, 2007 | 04:23 PM
bkubisht's Avatar
It's about 60 lbs of stuff altogether, located at 35806.
Requisite pics....
Old Feb 25, 2007 | 04:30 PM
bkubisht's Avatar
Here's the parts list of what I'm selling here:
Air box
Air bypass components
Charcoal canister
Coil/Ignitor
Cold start injector & supply tube
Coolant hardline that goes from middle of lower intake around to heater hose
Distributor
Ecu
Elbow for throttle body
Engine harness unwrapped, and completely uncut. all connectors labeled (ECU, sensors, etc) and all coolant sensors attached
Injector resistor
Lower intake assembly with fuel rail, injectors, thermostat housing pipe.
Throttle body with TPS attached
Upper intake plenum
Vaccuum hose routing assembly and EGR
Vacuum hoses for power steering load idle-up
If converting from 22R carb, you'd still need a fuel pump that'll deliver 40 psi, a fuel filter, O2 sensor and exhaust with a spot to install the O2.
edit: The sensor that is screwed into the thermostat housing is broken. I'm pretty sure this sensor just feeds the temp guage in the instrument cluster, so your old carb'd one should replace it just fine.
edit 2: My original ad said the intake was still assembled. I had disassembled it before the move and forgotten. I'll include all new gaskets for reassembly.
Old Mar 10, 2007 | 05:59 PM
Outsane's Avatar
tempting...
Old Mar 10, 2007 | 06:56 PM
bkubisht's Avatar
And still available too!
I noticed I didn't mention knock sensor. It's included, I just forgot to list it because it was one of the several sensors that I left attached to the harness.
Old Jun 17, 2007 | 02:01 PM
Mudboycole's Avatar
willing to sell just the ignitor? Email me at ryo_dn@hotmail.com if you are with a price that includes shipping to 50265 iowa zip code
Old Jun 21, 2007 | 07:44 PM
bkubisht's Avatar
Sorry, not willing to break up this set. TTT, this is still available.
I may have another setup from my '85 4runner, and am considering parting that one out instead of selling as a whole pile if there's enough interest in the parts. Is anyone interested in anything there besides the igniter?
Old Jun 25, 2007 | 02:56 AM
bkubisht's Avatar
Good news, I found the crossover tube. Someone's gotta need this. I still remember when the idea of rounding up everything needed for an EFI swap sounded kinda impossible.
Also, when I took the pics and repacked everything, I somehow fit it into a single big storage tub so shipping/handling will be much simpler.
Old Mar 4, 2008 | 06:25 AM
Mr Priceless's Avatar
is this still for sale?
Old Mar 5, 2008 | 04:07 PM
bkubisht's Avatar
This stuff got sold as a package deal a couple months ago. But I've since done an engine swap on my '85 4runner, and have most (but not quite all) '85 22RE stuff for sale. ECU, Igniter, etc. Posted here:
http://www.pirate4x4.com/forum/showthread.php?p=7910989
Old Apr 12, 2008 | 04:01 PM
fast68's Avatar
im going to have an identical setup from my DD 22RE 88 pickup i am scrapping out this week
complete truck nothing missing all good and running
thought i better say something before its gone
thanks
Randy
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
Fundy Rider
Jul 16, 2015 01:35 AM
Sandman
Jul 14, 2015 12:36 PM
bryan34w
Jul 6, 2015 05:53 PM
