BMW 3 series HID Bixenon projectors
Old Apr 8, 2007 | 01:52 AM
Keggo's Avatar
I'm selling the projectors that I used to do my HID retrofit into my 4Runner. I dismantled the headlights and decided to use different projectors for mine and my wife's new retrofits. If purchased I will supply a wiring harness that is set up for negative switch vehicles for ballast power AND power to the solenoids that control the high/low functions on the projectors. I'll get some updated pics on here shortly, but the projectors are in excellent shape. The wiring harness has an H4 connector to control the relays for the solenoid and a direct power feed line to the battery.
Looking to get $120 shipped though I AM flexible on pricing.
Thought some fellow YT'ers might be interested!
The lenses just have dust on them... they've been sitting out. They are not chipped or anything. The lens holder has some black paint on it, but the lenses are blemish free!! There is some leftover aluminum flashing tape sticky stuff (longest description... ever) on the outside of the reflector bowls. These projectors output light as if they were new!
Old Apr 8, 2007 | 07:37 PM
TRDatVT's Avatar
What else would i need to make these work?
Old Apr 8, 2007 | 10:00 PM
Keggo's Avatar
Bulbs and ballasts is pretty much it. Since you have clear lensed headlights already, you'd just have to modify your stock housings to mount these. check out www.hidplanet.com/forums for a TON of info on retrofitting!!
Old Apr 8, 2007 | 10:49 PM
Keggo's Avatar
Pictures added!
Old Apr 9, 2007 | 11:58 AM
kevin444's Avatar
I have g35 ballasts and, 6000k philips ultinon capsules and a headlights harness what else is needed to trigger the relays for the hi/lo beam motor?
Old Apr 9, 2007 | 03:47 PM
Keggo's Avatar
Dude... the circuit for the e46 solenoids on a negative switch system is horrible to make. I'll just send you my harness anyway if you purchase the projectors. I knew I'd see you, Kevin... lol Kevins and HID's... hahah. Here's the diagram for the power/solenoid harness :
Old Apr 10, 2007 | 10:33 PM
Keggo's Avatar
Bump!!
Old Apr 11, 2007 | 08:23 AM
Keggo's Avatar
flexible on price!
Old Apr 15, 2007 | 09:54 AM
Keggo's Avatar
Still Available!
Old Apr 16, 2007 | 12:28 AM
Keggo's Avatar
bump... Harness no longer available, due to dismantling for new harnesses...
Old Apr 28, 2007 | 09:08 AM
Keggo's Avatar
Bump...
Old May 5, 2007 | 08:52 PM
Keggo's Avatar
BUMP STILL available...
Old May 30, 2007 | 11:15 AM
Keggo's Avatar
Still available....
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
clok
Nov 19, 2015 01:09 PM
runnermedic
13
Sep 21, 2015 05:20 PM
larrys93pickup
Sep 17, 2015 07:05 PM
