1995 3.0 4Runner 5 speed
Old Jul 12, 2013 | 05:52 AM
jkgts1's Avatar
Originally Posted by Yamiryder
Shifter boots and tan bezel. $50 shipped
You have a chance to get the pedal set out? Thanks
Old Jul 12, 2013 | 05:58 AM
Yamiryder's Avatar
No I worked on it a little and now I broke my collarbone so its even harder to work on it now. I have time but only one arm ahha
Old Jul 12, 2013 | 06:53 AM
jkgts1's Avatar
Oh my bad, sorry to hear it. Just keep me posted then im not in any hurry. Thanks
Old Jul 14, 2013 | 08:27 PM
Yamiryder's Avatar
Thanks, you wanted the ECM too, right?
Old Jul 14, 2013 | 08:28 PM
  #25
StewsRunner's Avatar
coolant overflow reservoir? 96161
Old Jul 14, 2013 | 08:38 PM
  #26
Yamiryder's Avatar
$35 shipped?
Old Jul 14, 2013 | 10:43 PM
  #27
Cyberhorn The Dragon's Avatar
Old Jul 14, 2013 | 10:46 PM
  #28
jkgts1's Avatar
It turns out i dont need the ecm, just the pedal set. Thanks
Old Jul 16, 2013 | 09:13 PM
  #29
Yamiryder's Avatar
3.0 ECM $75 shipped
Old Jul 18, 2013 | 10:57 AM
  #30
vikingsven's Avatar
do you have the clutch slave and hardlines going to the clutch master?
Old Jul 24, 2013 | 06:05 AM
  #31
vikingsven's Avatar
anyone home?
Old Jul 24, 2013 | 07:34 AM
  #32
irab88's Avatar
would you consider shipping just the trans bellhousning?
Old Aug 1, 2013 | 05:29 AM
  #33
Yamiryder's Avatar
Sorry I never saw this. Possibly, motor and everything is still in it so I don't know when I could do that.
Old Aug 1, 2013 | 05:30 AM
  #34
Yamiryder's Avatar
Sorry this didn't pop up in my subscribed. Yes but the hard lines might be junk from rust. Slave is good though.
Old Aug 1, 2013 | 05:43 AM
  #35
vikingsven's Avatar
Ok. I'll pass on the hardline and slave. I'll just get a new one.
Do you have the lower bellhousing clutch inspection cover by chance?
Old Aug 1, 2013 | 05:45 AM
  #36
Yamiryder's Avatar
Probably but I don't even know what that is haha.
Old Aug 1, 2013 | 05:55 AM
  #37
irab88's Avatar
whenever, no rush. just keep it in mind whenever you happen to pull it
the r150f does not have an inspection cover. but if you need one, marlin has them new:
http://www.marlincrawler.com/transmi...llhousing-plug
Old Aug 1, 2013 | 06:06 AM
  #38
vikingsven's Avatar
Not a the rubber plug. I need the plate between the bellhousing and the engine block. Not sure if it is 2 pieces on a 3.0 truck or not, if it is I need the lower piece. (I'm working on a 3.4 swap with a r151f tranny. My donor had an auto with a 2 piece plate)
Old Aug 1, 2013 | 05:49 PM
  #39
irab88's Avatar
ah, ok.
(that's what i'm collecting parts for, too )
Old Aug 7, 2013 | 02:39 PM
  #40
exray's Avatar
I need the connector that plugs onto the Engine Coolant Sensor. That's the two wire one, brown and green are the primary colors. Mine was brittle inside and got damaged. Connector with 4 or 5 inches of pigtail attached would be ideal.
Thanks.
