zero offset wheels?
Old Dec 6, 2011 | 08:31 AM
kirkerik's Avatar
zero offset wheels?
i did a search but didn't find my answer... Does anyone know if i can run a zero offset rim? 15x6 6x 139.7 bolt pattern 4 1/4" bore +0 offset
ive got a 2nd generation pickup sr5. the offset i have on the stock rims appears to be about 2" ? i think?
Old Dec 6, 2011 | 02:54 PM
kirkerik's Avatar
so anyone know if a zero offset rim will fit?
i'd like to get the wheel/tire inside the fender well a little bit and i found some cool rims w/ zero offset.
Old Dec 7, 2011 | 02:33 PM
rusty87's Avatar
they will fit better than stock
Old Dec 7, 2011 | 05:10 PM
kirkerik's Avatar
How will they fit better?
the zero offset wheel will stick out farther, right? in other words stock wheels fit inside the well more?
Old Dec 7, 2011 | 07:05 PM
4Crawler's Avatar
Maybe the wheels you have are not stock. Stock backspacing on the IFS wheels is about 4-3/4"
On a 7" wide rim, this is 1-1/4" offset from center (never can remember which sign goes which way on offset - that's why I prefer backspacing, it makes more sense for fitting wheels to vehicles). In any even, that manes a 0 offset 7" wide wheel would stick out 1-1/4" wider than the stock wheel.
Old Dec 9, 2011 | 12:26 PM
kirkerik's Avatar
hey thanks 4crawler. the +/- offset thing is confusing.
1 1/4" out is not the direction i'm looking to go.
thanks
Old Dec 9, 2011 | 01:05 PM
4Crawler's Avatar
Information on determining track width:
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
Old Dec 9, 2011 | 01:40 PM
kirkerik's Avatar
thanks again!
good info
kouki420
Sep 2, 2015 11:42 AM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
skoti89
Jul 6, 2015 07:45 PM
