What PSI are you using w/ Bridgestone REVO s
Old Nov 12, 2005 | 02:52 PM
jcee76's Avatar
what air pressure are you guys using for on road use. For mainly durability for front and rear.? I have the 365/75/16 AT bridgestone Revo
I'm using 32psi all around
Old Nov 12, 2005 | 02:53 PM
AznSky's Avatar
40 on the street, I need the gas mileage
Old Nov 12, 2005 | 03:23 PM
ChickenLover's Avatar
I run 32.5 in the rear and 33.5 up front.
Old Nov 12, 2005 | 03:31 PM
marko3xl3's Avatar
32 both front and back (different car, not 4Runner...heavier SUV).
By the way, are you sure you mean 365 not 265?
Old Nov 12, 2005 | 06:11 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I had mine at 32 psi all the way around when I had my REVO's. Would air down to about 24-26 in deep snow.
Old Nov 12, 2005 | 06:27 PM
MTL_4runner's Avatar
Do they make them in 365's?
Old Nov 12, 2005 | 07:55 PM
srpage's Avatar
32 psi front and back
Old Nov 12, 2005 | 08:15 PM
northfacer581's Avatar
Originally Posted by jcee76
I just had a major service for 85k at toyota. They did the whole deal +changed my timing belt. And I noticed that I was only getting 17mpg after the service. By the way I also cleaned the throttle body out myself (They were going to charge me +$100 for that service). Continuing on... I changed my tires from a 265/65/16or17, I forget, to the A/T Revos 265/75/16or17. I saw my gas mileage average drop dramatically. My last tank I got 14.65mpg. Somethings wrong? or the revo's really eat gas? My driving habits are good comparable to my grandma's.
from another post.
im running about 42psi on the road (305/70/16) m/t's
Old Nov 12, 2005 | 08:58 PM
TechWrench's Avatar
35 front and rear.
Old Nov 13, 2005 | 05:54 AM
Rivalred's Avatar
Whatever the door sticker says from the factory since they are OEM Size, prob 32-35 front/back.
Old Nov 13, 2005 | 06:13 AM
FilthyRich's Avatar
about 35 on the revos (wife's)
37 on my MT/Rs
Old Nov 13, 2005 | 11:28 AM
89macrunner's Avatar
my dad has 265/70/16's and he runs 35psi
if your running 365's...which i dont think revos come in...32 psi is WAY too low
Old Nov 14, 2005 | 05:44 AM
X-AWDriver's Avatar
With my Nittos I'm at 35psi all around but i'm still experimenting since the tires only have 200 miles on 'em.
Old Nov 16, 2005 | 05:36 PM
jcee76's Avatar
correct I have the 265/75-16... 32psi kinda low? I kinda want to bump it up to maybe 37psi all around.
Is that going to give me better gas mileage and longer tread life?
Old Nov 16, 2005 | 06:27 PM
tulsa_97SR5's Avatar
I'm at 32 also, had them higher for a while, but it was clear they were over inflated. When it drive though wet patches then park the middle would be dry, and the outside still wet, showed that the middle was making more contact with the ground & would eventually cause them to wear wrong. Same thing driving across dusty ground, the middle got clean right away. My experience with revo's is that they have a pretty small correct inflation range, a little too high or low and they'll wear funny. Kinda like the chalk test i've seen on here to determine the correct inflation.
Old Nov 16, 2005 | 10:23 PM
L33T35T 4Runner's Avatar
when you change tire size, your correct tire pressure is one of which you have even tire contact across the tread. i run about 26 psi. anything more, only the center of my tires are touching the ground.
Old Nov 16, 2005 | 10:49 PM
TechWrench's Avatar
That will depend on how you drive, and how you would like the vehicle to ride.
Generally, the harder the tire (higher pressure), you get less rolling resistance.
This should equate to somewhat better mileage. As for tread life, if you set the pressure too high, the center of the tread tends to wear quicker that the outer edges. Too low a pressure, and the reverse is the case, in addition to increasing the operating temp of the tire because of additional sidewall flex.
You sorta have to figure it out for yourself. I run mine at 35. Tried 37, but the steering tended to wander. But your vehicle may be different.
Old Nov 17, 2005 | 03:16 AM
Ilovemountains's Avatar
mine are not the same size but
Mine are not the same size but I run 25 in the rear and 32 in the front, I also have a pickup with a light fiberglass bed so the rear is very light and the 3.0 up front so the front run a little more.... Just my .02
dc42nr86
Oct 4, 2010 04:39 PM
iaonbb
Oct 12, 2005 08:26 PM
iaonbb
Aug 23, 2005 12:01 PM
austin
Dec 31, 2004 04:49 PM
4FonZ
May 10, 2004 03:06 PM
