Trying to find out if these would fit my 1985 truck
Old Jan 15, 2013 | 06:17 PM
mtb83201's Avatar
Everything looks ok except I'm not sure on the diameter for the center bore.
http://www.summitracing.com/parts/sum-85-6883/overview/
Old Jan 15, 2013 | 06:21 PM
HighLux's Avatar
When in doubt....give em a call..
Old Jan 15, 2013 | 06:30 PM
mtb83201's Avatar
Ya, I tried that. They weren't super helpful. Looks like the center bore is too small on these. "Center Bore Diameter (mm): 107.95mm"
Old Jan 15, 2013 | 06:57 PM
snobdds's Avatar
I read on summit the center bore was 4.25, which is what you want. The OEM center bore is 4 1/8 on any 40,45, 55, 60, 80, 100, 200 (Landcruisers), mini truck/4runner, or Tacoma wheel. Don't know about the Tundra, I heard they went to a 5 lug wheel.
You will want less backspacing on that 85 of yours. I am pretty sure solid axel stock backspacing was 3 3/8, 4 inches to too much. You might run into your tire hitting some steering stuff.
Old Jan 16, 2013 | 03:49 AM
suppra87's Avatar
Check out the fitment calculator on this website, http://www.willtheyfit.com
You can play around with the size wheel and tire you have now and compare to what your interested in buying.
Old Jan 16, 2013 | 04:51 AM
waskillywabbit's Avatar
3.75" backspacing is what you want or you'll hit stuff.
:wabbit2:
Old Jan 28, 2013 | 05:15 PM
saltandgranite's Avatar
Don't ever buy steel wheels! Get aluminum.
shadowbirdie
Jul 1, 2015 05:14 PM
Eagle564
Jun 23, 2015 11:29 PM
ACZR
Jun 23, 2015 07:55 PM
JaredL
Jun 16, 2015 04:47 PM
Luke
Jul 8, 2002 04:22 PM
