tire tubes/where to find
Old Jul 17, 2010 | 02:10 AM
dipsherry's Avatar
i need tubes for my 38" tsl on 15" rims anyone know if there is a place to purchase tubes or if this size is even avalible thanks
Old Jul 17, 2010 | 06:00 AM
xxxtreme22r's Avatar
try a local tractor tire supply store. Are you sure your tires even need them?
Old Jul 17, 2010 | 06:09 AM
dipsherry's Avatar
they all leak around the rim and i hate putting rubber cement around the rim cause it never lets any tire seat right
Old Jul 17, 2010 | 06:33 AM
waskillywabbit's Avatar
Beadlocks.
Old Jul 17, 2010 | 06:55 AM
Originally Posted by waskillywabbit
Beadlocks.
there you go problem solved.
As far as sealing goes, if they leak around the edges then you got other issues that the tubes will not fix.
BTW tubes are not cheap. If the tires are leaking because of the bent rim on the wheels then it might just be cheaper to get new rims. That's if the tires don't have tubes already. Sounds like they don't since you want to band aide fix something with what will probably cost you $60-70+ a tube
Is it even a good idea to run tubes on a tire not designed for them anyway?
Old Jul 17, 2010 | 07:13 AM
dipsherry's Avatar
thanks guys i guess i will pick up a new set of wheels and i figure that would solve my problem. just trying to be cheap but i know you get what you pay for
Old Jul 17, 2010 | 07:49 AM
I wouldn't exactly call buying 4 tubes for tires that may not be designed for them (I can't confirm if they are or are not as I don't now which TSL's you have, as some do and some dont) Nor do I know if you are looking to by one or a full set, you never said if they have tubes in them already or not. If you said they leak, I think it's safe for me to assume they aren't.
Alot of us here don't agree with the way some of us (inluding myself) want to fix a problem. And will mention an easier/cheaper/more reliable etc. way out. In no way are we making fun of or trying to run you off. Just trying to help out.
Most of us don't want to see someone take the hard/more expensive way around something.
Old Jul 17, 2010 | 08:10 AM
dipsherry's Avatar
i completely understand what you mean i only have one tire that leaks i cannot see any visible bends in the rim but i know air can find its way out of small places. it is strictly a trail rig and the tires are bias ply but never have i used tubes in any bias ply tires before i have a old rim i am gonna try. Also i am very easy going and enjoy constructive criticism any knowledge is good knowledge. So don't worry you didn't offend me at all thanks.
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
DrZero
Jul 13, 2015 09:59 AM
Yotoder865
Jul 9, 2015 07:51 PM
