Tire pressure for Bridgestone Revos on Prerunner
Okay, I've got a 2000 Xtra Cab 2.7L auto Prerunner. I've some 31x10.50 Revo's on it. I really like these tires. The Manual calls for 26psi front and 29psi rear for a 31x10.50 tire.
What are you guys running these tires at?
Also, for a 265/75 it say to use 26psi all the way around. I thought the 265/75 was the same as the 31x10.50?? I wonder why they recommend different pressures.
I also can't understand why they call for more air in the rear tires than the front. The front should weigh more w/ the engine being up their. I know the heavier you go, the more air you use.
Any advice will be appreciated w/ these tires.
09-04-2015 09:27 AM
itzmywife's
07-25-2015 04:55 PM
skoti89
07-08-2015 12:05 AM
