Should I get bigger tires??
Old May 19, 2020 | 06:17 PM
Junetaco90's Avatar
Debating on putting 33’s on my 84 or should I stick with the 31’s I currently have?? Maybe it will only look more aggressive but any Benefits? I haven’t had any problems going on some mid aggressive trails
Old May 19, 2020 | 09:38 PM
SomedayJ's Avatar
I like this way.
Nice truck!
Old May 19, 2020 | 11:06 PM
RAD4Runner's Avatar
No.Looks good as it is.
Old May 20, 2020 | 12:36 PM
Jaketheone46's Avatar
I like it like it is too. What size are they and also what gearing are you running?? Mine has the stock 4.10 gearing and with the 31x10.50 I’m running I definitely wouldn’t want to go any larger due to the gearing would need to change for sure. These little 22r don’t care for the big tires so if I was to go bigger I would definitely make sure it’s geared to the tire size. Also with the ground clearance on these little trucks big tires just aren’t really necessary.
Your truck looks great as it sits.
Old Nov 12, 2020 | 05:38 AM
sametoce's Avatar
Did you go for bigger tires?
Old Nov 12, 2020 | 05:46 AM
Junetaco90's Avatar
no I kept it the same love the way it runs now, don’t want to risk taking that away by adding bigger tires without upgrading gears.
space-junk
813
Nov 18, 2021 09:00 AM
Benson X
Dec 12, 2012 11:13 AM
4RunnerMN
May 22, 2011 06:06 AM
