Largest/beefy-est tires without rubbing on stock 06 Tacoma?
Old Oct 20, 2009 | 12:52 PM
sickspeed's Avatar
i have an 06 non-trd tacoma extended cab and i was wondering what the biggest tires i could get on it without rubbing would be. i plan on keeping the stock suspension and dont really have a need to raise it at all since i rarely go off road. i guess you could say this is more for cosmetic purposes. can i get 31" x 10.5? and what about 15" or 16" wheel size? i currently have 16" wheels but would be open to going to 15s. thanks.
Old Nov 3, 2009 | 12:26 PM
atmotocrosser's Avatar
Also interested...does anybody know the answer to this?
Old Nov 3, 2009 | 12:39 PM
dannomite's Avatar
You should probably state your intended use for the truck. If you are actually going to use it off road then I think 265/75r16 (31") is the largest. I am going off of my buddies truck which is a 06 with the trd package. When he flexes out there is a bit of room before rubbing but not much. If you are only running it on the street you may be able to go bigger. I don't know.
Old Nov 3, 2009 | 01:15 PM
sickspeed's Avatar
Thanks. Thats kinda what I was after
although i actually get some rubbing (or what sounds like it) now and i 245/75/16. i am still trying to nail it down but it seems to do it when i am breaking, or flexing a bit, and turning. so i was kinda wondering if a 265/70/16 would be a good option. and i dont have the trd suspension which i believe is a bit stiffer and possibly a smidge higher than the non-trd. oh and like i said, my intent is light off-road so mostly just daily driving on roads.
Old Nov 3, 2009 | 01:35 PM
HazMat's Avatar
Probably cannot go to a 15 inch wheel with your taco. the brakes are simply just too big. But on your 16 inch stock wheels you may be able to run 265/75/16s with little to no problems.
Old Apr 26, 2012 | 10:40 AM
whitejedi's Avatar
My stock 09
I have 275/45 20's on my stock 09' standard 2wd, 31 10.5's will fit, mud tires may hit the fender inset- bit you can take it out
Flying91
45
Apr 11, 2024 04:39 PM
djpg2000
Nov 11, 2020 04:56 AM
DrZero
Jul 13, 2015 09:59 AM
Yotoder865
Jul 9, 2015 07:51 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
