Chevy Rims 16x7 with 3.5BS fit on stock 2000 4runner with 265/70r16
Old Aug 28, 2015 | 03:29 PM
Jamie4runner2000's Avatar
Will they fit? Chevy Rims 16x7, 3.5BS with 265/70r16 on stock 2000 4runner
Hey Guys,
http://www.kijiji.ca/v-tires-rims/lo...ota/1097557398
Does anyone know if these chevy rims will fit a stock 2000 4runner.
I will be mounting 265/70r16 rubbers on the 16x7 chevy rims with 3.5 back spacing. Should I have to worry about rubbing at all? I have stock suspension and no lifts on my 4runner.
Thanks in advance,
Jamie
Old Sep 2, 2015 | 11:36 AM
RPTFE00's Avatar
I just got wheels that have an offset of -12 and my stock Yota wheels have an offset of +6 same wheel dimensions as far as width and diameter, only problem I have is the inside just barely grazes my caliper. So I need some spacers for that. Make sure that the bolt pattern in the exact same or it won't fit right on the hub. I think these are 6x5.5 or 6x139.7. (They're both the same one is inches, the other, mm) I have no rubbing on my tires and I have no lift with 31x10.5 tires.
Old Jun 20, 2016 | 09:13 AM
bccooper's Avatar
The bolt pattern of the wheels are the same, the only issue you will run into is the chevy hub is alot smaller than the toyota so you will have to do some cutting to get them to fit.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
