best street-performing 30s
Old Nov 11, 2011 | 06:56 PM
abelisv's Avatar
What 30 inch tires that will fit 16X8" rims, will perform the best on the road? how wide? what weel/tire combo would provide the best street handling performance?
thanks,
abel
Old Nov 15, 2011 | 05:45 AM
abelisv's Avatar
is this really too retarted to even answer?
Old Nov 15, 2011 | 05:54 AM
CTRJ's Avatar
It might help if you posted what it was going on. A 30" tire on a 16x8 would be a 245/75-16 which is mostly available in load range E tires meant for full size truck applications.
Old Nov 15, 2011 | 06:03 AM
abelisv's Avatar
ok ignore all of that above.
What rim and tire combo would be best for the street on a stock height 88' 4cyl regular cab pickup? What tires would best fit the application on the stock size rims?
Old Nov 15, 2011 | 05:03 PM
CTRJ's Avatar
According to Tire Rack, there were two sizes available for your 88. If it was my truck, I would look at size 205/70-14 and look at the BFG Radial TA. I had a set of these years ago on my Tacoma 2wd and they were great tires.
Old Nov 17, 2011 | 11:11 AM
peow130's Avatar
He shouldnt have 14" rims on his 4x4..
First, you need to find out what size rims you currently have, then decide if you want stock size (235/75-15), or if you want to go up to a 30" tire, or a 31" tire..
I have 30x9.5r15 Cooper Discoverer ST's on my truck, and they perform well both onroad and offroad, with great on-road manners and minimal highway noise.
Pretty good treadwear life too, i'm at 40k right now with about 1/4 tread left.
However, you can get a MUCH higher variety of tires in 31x10.5... And, your truck will probably look better. I know when i get new tires i'm going 31x10.5's, or 33x10.5s
Old Nov 18, 2011 | 07:12 PM
CTRJ's Avatar
The OP actually didn't specify and I guess I saw "street performance" and assumed it was a 2wd.
If it is indeed a 4wd and stock and you don't off-road, I would go with 235/75-15. This will keep the engine from laboring with larger tires and keep your fuel mileage decent. I would recommend a set of Falken High Country AT's. I have them on my truck and they are great on the street, in the rain and snow and off-road.
HappyCamper
Nov 2, 2015 10:41 AM
Z's Confederate Toy
47
Aug 21, 2015 05:44 AM
combatcarl
Oct 19, 2012 01:51 PM
2002 SportEdition
14
Jul 9, 2004 10:27 AM
