5'' backspacing on 85 toyota
Old Apr 11, 2010 | 04:35 PM
Albert.G's Avatar
Alright well I just bought some 16x8 crager soft 8's and the backspacing is 5'' will it be alright with a 315x75r16 with 1.5 spacers? help would be unreal...thanks guys and gals..
Old Apr 11, 2010 | 06:42 PM
4Crawler's Avatar
Probably be a tight fit. Stock backspacing is 3-3/8" and I found I was nearly rubbing the springs up front with 33x9.50 tires. May need to crank out the steering stops a bit or get a wider spacer.
Old Apr 11, 2010 | 08:28 PM
Albert.G's Avatar
ughh I thought so, You think 4.25 would be better? with that 1.5 spacer?
Old Apr 12, 2010 | 05:38 AM
4Crawler's Avatar
That would give you 3/4" more clearance inside. Probably be a better fit.
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
