Domestic Swaps Chevrolet, Ford, ect
Weld-In mounts for 1993 with Chevy V8 ??
Old Sep 22, 2008 | 11:36 AM
RevNL's Avatar
I want to get rid of the body lift on my 1993 Pickup with a Chevy V8. Since I've ditched the IFS for a solid axle, I don't need the Advance Adapter mount adapters anymore.
The plan is to torch off the 22RE pads, use the Advance Adapters weld-in style mounts (for a 79-85 truck), mount the engine 3" lower than it was, and remove the body lift completely.
Anyone know of a reason I shouldn't do this?
Old Sep 29, 2008 | 06:44 PM
RevNL's Avatar
The Advance Adapters weld-in mounts came in today. With the frame-side mounts in the upright position, the engine will be 3" lower than with the bolt-in mounts (obviously why you can't use them with IFS). With the the frame-side mounts in the inverted position, the engine would be 7" lower.
Looking good so far...
Old Oct 1, 2008 | 11:47 PM
fillsrunner4's Avatar
Post up some pics!
Gonna be nice having the motor down lower! the lower the better
Old Oct 4, 2008 | 08:03 PM
Adam F's Avatar
Low is nice for COG, but I chose to mount my engine higher up, in order to tuck the transfer case up high and build a high clearance xmember, and to raise the gas tank to match. Just my $.02
Old Oct 7, 2008 | 05:49 PM
Doenst really need to be mounted very high in order to tuck the tranny up.
The 4.3 is definetly not as tall as my old 3.4 was but i left my tranny were it was and was able to keep the motor low aswell.
Only downfall here is driveline angles and it is raising the COG. To compensate some I lowere the stance of the runner and its just about perfect now
Old Oct 8, 2008 | 06:21 PM
Adam F's Avatar
Looks about as high as mine is. I left enough room in between the body and the trans to allow for movement and ease of trans removal.
Old Oct 8, 2008 | 06:25 PM
No dude that looks real good and low Gonna mob too
Jamie4runner2000
Jun 20, 2016 09:13 AM
Ryall
Sep 2, 2015 06:48 AM
c0de_red1
Engine Swaps
Aug 30, 2015 11:13 AM
norcal98
Aug 10, 2015 06:20 AM
priest16
15
Aug 6, 2015 07:43 AM
