Domestic Swaps Chevrolet, Ford, ect
V8 Toyota 4runner gauge options??
Old Oct 15, 2009 | 10:48 AM
cbrwags's Avatar
I have a sbc engine in my 1990 4runner and want the factory gauges to work. I could use some help finding the tach output wire that I can hookup to the coil as for the temp I have an idea to use a stock v6 unit from a junkyard along with oil pressure unit I just need the gauge to work and dont want to blow the cluster so on that I could also use some help on getting the right sending unit and the right wire to in the cluster to run to.
Old Oct 16, 2009 | 08:55 PM
Adam F's Avatar
All the factory gauges work in my truck.
For the tach, I probed the wires and found the wire in the harness that was connected to the tach input on the gauge. I then spliced that wire into the tach ouput terminal on my HEI distributor.
Once I had it hooked up, I had to adjust the potentiometer in the cluster to compensate for a V8. I used a timing light that had an RPM readout and matched it to that.
For the oil pressure gauge, I used the stock Toy sender and wire. I had to get a 90 degree adapter so it would fit under the distributor.
I used a reducer to fit the stock water temp gauge sender in the block, along with the original wire.
Old Oct 17, 2009 | 12:24 PM
cbrwags's Avatar
Thanks for the info. Do you know what wire is from the tach? I also need what wire from the cluster is for the temp and oil pressure someone cut the wires I can probe them like you said but if I can get a color of what wires I need that would help so much and save me a load of work.
Old Oct 18, 2009 | 08:03 PM
Adam F's Avatar
I cant remember off the top of my head. When I get some time I can check. Might be a while though. Plus, mine is a 1st gen, yours is a 2nd, so its probably not the same.
One way to find out is to download an FSM and go through the wiring diagrams.
Here's a link
http://www.ncttora.com/fsm/1990-1995...es/wiring.html
Old Oct 19, 2009 | 09:53 PM
cbrwags's Avatar
That is great Thanks Adam.
vasinvictor
Jan 20, 2016 12:39 PM
JaredL
Jun 16, 2015 04:47 PM
sassy4runnerchic
18
Jun 6, 2002 02:21 PM
