Domestic Swaps Chevrolet, Ford, ect
power steering on sbc swap??
Old May 28, 2009 | 02:59 PM
Ron's 85's Avatar
is anybody with a short water pump running a chevy power steering pump. i dont have any room, but i am ready for power steering should i try a toyota pump instead????
Old May 28, 2009 | 03:09 PM
fillsrunner4's Avatar
You dont have room cause of the water pump? Or just no room under the hood for it? Maybe a pic would help.
Old May 28, 2009 | 03:19 PM
Ron's 85's Avatar
i cant get the pulleys to line up, the pump is shuved up too tight to the block and is stiil too far into the radiator. i have no body lift. i need to keep fabbing i guess. it might end up mounting on the fender well.
Old May 28, 2009 | 03:31 PM
That sounds odd the pump wont bolt back in. the rad thing I could see as its a long block but whats making the stock pump not bolt to its stock location on the block?? did you remove the pulley off the pump when you took it off and if so did you get it pressed back in all the way. Im amagining my 4.3s pump which is very similar to some 350 pumps
Old May 28, 2009 | 03:44 PM
Ron's 85's Avatar
i build this block up and used a short water pump for clearance up front, which brings my pulleys closer to the block. if i mount the pump to the right of the water pump(looking at the motor from the bumper) it won't line up with my existing pulleys. the pump i got used and the pulley seams to be all the way on. i can get some pictures tomorrow when i head back to the shop. im trying to troubleshoot a little tonight so im fresh tomorrow.
Old May 28, 2009 | 03:51 PM
do you have a pump w/resovor (one unit) or pump without? Sorry Im not really more help. but I would wonder if you were gonna have to get one without the resovor and add one in. I could see it being a better fit maybe.
Hope you get it all figured out. im sure you will
Old May 28, 2009 | 03:57 PM
Ron's 85's Avatar
thanks for the help fellow washington wheeler. i kinda hit the wall today, but i will figure it out. the pump has a reservior looking cap on the top, i guess it's an all in one. there isn't enough time in a day!!!
i just ditched my five speed bellhousing conversion for an auto 350, now the old lady loves to drive it, but shes a little too pitite to yank on the wheel like i do.. it's time for power steering!!!
Old May 28, 2009 | 04:06 PM
I hear yeah as ive hit it many times. Im still trying to get mine wired and have no time during the day to cause im stuck at work.
Ide maybe look into one without the cap. which BTW yours is the pump W/res
Old May 29, 2009 | 05:19 AM
Adam F's Avatar
Your problem is, you dont have the correct mounting bracket for the pump. There are 2 different mounts, one for a long water pump, and one for a short water pump.
Sounds like you are trying to use a mount for a long water pump, with a short water pump.
Get the correct mount and the pulleys will line up.
Old May 29, 2009 | 07:00 AM
Ron's 85's Avatar
im ballin on a budget over here, so i think i'll fab up my own bracket. thanks for the info.
Flying91
45
Apr 11, 2024 04:39 PM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
