LS1 Swap
#121
So here we go again. When this build started, I, frothing at the mouth, pretty much jumped at the first EFI control system I saw and it didn't take long to see that the one I chose was the wrong one. The truck ran fine but not quite what I was expecting. The truck is back in the barn for a transplant, this time with the -411 ecm that it needed from the start, flashed to spec.
Of course engine and dash removal required
#125
Not for awhile. I've had the truck for about 6 months now the P.O. was a steamy pile of a human. I've rebuilt the ifs in the front. Fixed the cooling system before the 3vze did the 3vze thing *headgaskets* and just recently had to rewire the injector harness.
#127
Uh, yeah, you don't have to rub it in! (j/k) You know what they say, precision takes time, so does a full time job and family. I don't know if there really is an end except when I sell the truck. Keep reading...
I thought I'd do a conditional inspection while I had the engine out. The bearings looked pretty good, the inside was clean but found one small issue
Other than that, it looked fine.
#130
Wow, you made quick work of tearing her back down! All that wiring would intimidate me, lol. I hope the block checks out and is still good. Look forward to seeing your progress!
#131
The crack is hard to see in the pics but its there and all the way through the sleeve wall. It extends about 1/2in. down. I talked to a local machine shop about it and he said the sleeve (difference between a sleeve and liner is that liners are generally wet) can be removed and replaced, so I may have dodged a bullet there.
#132
Subscribed! I'm working on final engine placement and wiring harness right now. Glad to see this thread is active again and that you're going with a stock ecu. I'm using it as well. Running a 4l60e/208 and trying to decide between 5.3 and 6.0. Both are in the garage. With the 6.0 I'll need hp tuners,5.3 I won't need hpt until heads/cam. I still have a long way to go, need to make a build thread. Anyways, awesome work! I'll be watching and likely asking questions along the way
#138
Finally going back together. Wasn't planning on a total bottom end but guess I'll take it. The shop wound up doing right by me after their little boo-boo on the bench.
