Domestic Swaps Chevrolet, Ford, ect
LS1 Swap
Old Mar 6, 2016 | 01:47 PM
  #121
88ECToy's Avatar
So here we go again. When this build started, I, frothing at the mouth, pretty much jumped at the first EFI control system I saw and it didn't take long to see that the one I chose was the wrong one. The truck ran fine but not quite what I was expecting. The truck is back in the barn for a transplant, this time with the -411 ecm that it needed from the start, flashed to spec.
Of course engine and dash removal required
Old Mar 6, 2016 | 02:01 PM
  #122
88ECToy's Avatar
it's also a good time to address the drag link/tie rod bind by relocating and rotating the box
Old Mar 9, 2016 | 05:55 AM
  #123
coffey50's Avatar
So glad to see the build thread again. Its funny you mentioned jumping at the first ECU. When I do my LSx swap own my T4R I plain on using MSD Atomic wiredless EFI for an LS1. It just looks so clean.
Old Mar 12, 2016 | 10:41 AM
  #124
88ECToy's Avatar
Yeah, that would clean things up measurably. When does this project begin?
Old Mar 14, 2016 | 02:51 AM
  #125
coffey50's Avatar
Not for awhile. I've had the truck for about 6 months now the P.O. was a steamy pile of a human. I've rebuilt the ifs in the front. Fixed the cooling system before the 3vze did the 3vze thing *headgaskets* and just recently had to rewire the injector harness.
Old Mar 14, 2016 | 07:11 AM
  #126
amalik's Avatar
sorry for skipping all 7 pages.
you are 4 years into this project?
Old Mar 15, 2016 | 07:22 AM
  #127
88ECToy's Avatar
Uh, yeah, you don't have to rub it in! (j/k) You know what they say, precision takes time, so does a full time job and family. I don't know if there really is an end except when I sell the truck. Keep reading...
I thought I'd do a conditional inspection while I had the engine out. The bearings looked pretty good, the inside was clean but found one small issue
Other than that, it looked fine.
Old Mar 15, 2016 | 07:25 AM
  #128
coffey50's Avatar
#MorePiston lol Seriously though is that damage enough to warrant boring it to restore a perfect cylinder wall ?
Old Mar 15, 2016 | 07:28 AM
  #129
88ECToy's Avatar
I have to see if the liner can be replaced or if the block is junk.
Old Mar 17, 2016 | 09:31 AM
  #130
rustED's Avatar
Wow, you made quick work of tearing her back down! All that wiring would intimidate me, lol. I hope the block checks out and is still good. Look forward to seeing your progress!
Old Mar 17, 2016 | 04:13 PM
  #131
88ECToy's Avatar
The crack is hard to see in the pics but its there and all the way through the sleeve wall. It extends about 1/2in. down. I talked to a local machine shop about it and he said the sleeve (difference between a sleeve and liner is that liners are generally wet) can be removed and replaced, so I may have dodged a bullet there.
Old Mar 18, 2016 | 09:57 PM
  #132
rooster18's Avatar
Subscribed! I'm working on final engine placement and wiring harness right now. Glad to see this thread is active again and that you're going with a stock ecu. I'm using it as well. Running a 4l60e/208 and trying to decide between 5.3 and 6.0. Both are in the garage. With the 6.0 I'll need hp tuners,5.3 I won't need hpt until heads/cam. I still have a long way to go, need to make a build thread. Anyways, awesome work! I'll be watching and likely asking questions along the way
Old Mar 19, 2016 | 11:06 AM
  #133
88ECToy's Avatar
Thanks, Rooster. I hope you'll start that thread as there's something to learn from everyone who does this swap. Are you using the stock harness?
Old Mar 19, 2016 | 08:52 PM
  #134
rooster18's Avatar
Yes stock harness. I'll try and get a thread up tomorrow. I have to get updated pics of everything.
Old Apr 10, 2016 | 03:14 PM
  #135
rustED's Avatar
Hey Les, any updates on the motor?
Old Apr 10, 2016 | 05:45 PM
  #136
88ECToy's Avatar
Ya, Ed. The shop is building up another short block that should be done this week. I'm ready to be done with this as my level of confidence isn't high.
Old Apr 11, 2016 | 08:49 PM
  #137
rustED's Avatar
Hope everything goes smoothly for you...I'm sure it will, you got some mad skills!
Old Apr 19, 2016 | 06:30 AM
  #138
88ECToy's Avatar
Finally going back together. Wasn't planning on a total bottom end but guess I'll take it. The shop wound up doing right by me after their little boo-boo on the bench.
Old Apr 19, 2016 | 07:21 AM
  #139
irab88's Avatar
Someone's an A&P
Old Apr 19, 2016 | 07:43 AM
  #140
Evan Tucker's Avatar
Hair straight back and go!
