Domestic Swaps Chevrolet, Ford, ect
93' 4runner with 4.3v6 th400 &np208
Old Oct 31, 2011 | 03:24 AM
NWOleman's Avatar
Ok so i'm pretty new to the toyota scene but have done plenty of swaps in chevys. I have a 93' 4runner with the 3.0 v6 5speed (r151 i guess) and i have no idea what t/c? I just picked up a th400 np208 combo out of a 90' suburban and i'm picking up my 4.3 v6 that's out of a 94' chevy pickup. This rig is gonna be a street machine for now and later hopefully build it up for offroad use. My plan is to have this swap up and running by christmas. I'm gonna put a carb and hei on it for simplicity of getting the swap done easier, i figure i can always do fuel injection later. So if anybody has done this exact combo or very similar combo(th350 np208) any hints or info you can give me would be great! I''m thinking of getting a 2" bodylift for it and a clocking ring for the t/c also as these 2 mods should both be easier to do with the drivetrain out of the rig and will make this swap a lil bit easier. I will try to document my build with plenty of pics and what i learn as i go. Hopefully will get the tranny and transfer case removed this weekend and with a bit of luck the motor 2! Thanks in advance guys!
Old Oct 31, 2011 | 05:30 AM
NWOleman's Avatar
A few things i forgot... Planning on using an Advanced Adapters engine mount kit. Who has used one of these and were you happy with it? Also want to use the stock exhaust manifolds and a jegs starter. Probably gonna use a GM 1 wire 100amp alt too. Not too sure what to do about the power steering but i'm planning on use the stock one and hopefully the brackets won't be to bad to fab up or maybe even just modify the toyota ones to the 4.3. Also plan on using the stock radiator and fuel pump, i seen on here a few other guys were using there stock ones. There will be plenty of other stuff i know but i will tackle them when i come to them. Hopefully its not raining tonight after work, i wanna get that tranny and t/c pulled!
Old Nov 1, 2011 | 04:52 AM
NWOleman's Avatar
Thanks for the input guys!
Old Nov 2, 2011 | 06:59 AM
NWOleman's Avatar
Well i guess i will keep talking to myself. Got therear driveline pulled, radiator removed, a bunch of bellhousing bolts removed, all but 2 of the crossmember bolts out, and some electrical plugs unhooked. My weekend starts 2day after work so i'm feeling good bout getn the tranny t/c removed this weekend and hopefully the motor!
Old Nov 4, 2011 | 04:25 AM
NWOleman's Avatar
Gotthe tranny and t/c removed last night. Hopefully get the motor out tonight or tomorrow.
Old Nov 6, 2011 | 02:27 AM
NWOleman's Avatar
Motor is out and engine bay is pressure washed. Got the 4.3 home and getting it cleaned up. Intake and flexplate arrived. Clocking ring, distributor, and bodylift ordered. Ordering motor mounts today.
Old Nov 6, 2011 | 07:50 AM
lgarduno's Avatar
The AA motor mounts will work fine, as you are going to put a8 body lift on it. Good luck with it. I have kind of stalled out on mine but getting back to working on mine.
Old Nov 6, 2011 | 08:03 AM
NWOleman's Avatar
Thanks man. I know how it is on projects, way easy to get burnt out and discouraged! Buy some beer and bribe a few friends to come help ya work on it, that will get ya going on it again!
Old Nov 8, 2011 | 03:54 AM
NWOleman's Avatar
Body lift arrived already! Sweet! Thanks 4crawler, nice quality2!
Old Nov 13, 2011 | 04:40 AM
NWOleman's Avatar
Bodylift installed. Motor mounts, HEI type distributor arrived. Waiting on the clocking ring and for hunting season to be over.
Old Nov 20, 2011 | 06:10 PM
pettybilt's Avatar
Hey bro, i have a 700r4 and a 208 in my 87 4 runner with no body lift. I have a few pictures while i was building it i can post. I did'nt do a build tread, so i don't have a ton of pics. I did use a clocking ring in the middle position which put the t case about in the same position as the stock t case.
Old Nov 21, 2011 | 03:48 AM
NWOleman's Avatar
Yeah that would be cool! Thanks man! Planning on dropping the motor in on tuesday. Got the new motor mounts and flexplate on it last night. I think i'm gonna put the motor and tranny in as one peice then put the transfer case in from the bottom.
Old Nov 30, 2011 | 06:21 AM
NWOleman's Avatar
Had a small setback, had the wrong flexplate for the torque converter. Got the new one on and the tranny and torque converter bolted up. Cutting the old motor mounts off tonight and hopefully dropping the motor in tonight for test fitting.
Old Nov 30, 2011 | 04:21 PM
pettybilt's Avatar
[quote= I think i'm gonna put the motor and tranny in as one peice then put the transfer case in from the bottom.[/quote
I put the tranny on a jack then dropped the motor in, then bolted the t case up. Seemed to work well.
Old Nov 30, 2011 | 04:45 PM
pettybilt's Avatar
Pics of my swap
Here's some pics.
Old Dec 4, 2011 | 03:18 AM
NWOleman's Avatar
Thanks for the pics man! I still have the ifs in mine. I did get the motor mounts welded in and the crossmember modified and welded up. The motor, tranny, and t/c are in and bolted up 2. Pulled the gas tank so i could modify the crossmember for clearance for the driveline. Also started building my headers. Also got the distributor in, had to adjust the firewall a bit.
Old Dec 14, 2011 | 05:25 AM
NWOleman's Avatar
Headers are built and in. Gas tank is back in and e brake cable relocated. Hopefully more progress this weekend.
Old Dec 14, 2011 | 01:22 PM
eric924run's Avatar
Sounds good so far. more pics please.
Old Dec 26, 2011 | 12:49 PM
NWOleman's Avatar
Old Dec 26, 2011 | 12:50 PM
NWOleman's Avatar
