Domestic Swaps Chevrolet, Ford, ect
92 350 efi swap in an 84 pickup. questions
Old Apr 12, 2009 | 08:57 AM
Jfoust's Avatar
Question 92 350 efi swap in an 84 pickup. questions
Ok i have been searching the forums for differents types of answers. But not having much luck finding it.
Ok I have an 84 toy 4x4 22r
I have laying around is an 92 350, with the wiring harrness and ecu.
I know of advanced adapters for the motor mounts and such. but im not wanting to use the stock drivetrain. but go with la80e trans and transfer case. obviously fabbed in with a cross member and what not.
1) But with the efi does anyone have any ideas for the fuel pump? and if i need to swap out the tank, which tank would work?
Or just and ideas and sugusstions would be great as well.
Thanks
Josh
Old Apr 12, 2009 | 09:17 AM
89silverpu's Avatar
Try Pirate4x4.com
Link to some engine swaps in yotas...
http://pirate4x4.com/forum/search.php?searchid=4533599
Old Apr 12, 2009 | 07:01 PM
Adam F's Avatar
The stock chevy pump should fit right in place of the stock Toyota pump. Or actually I think you can use the stock toyota pump.
Old Apr 13, 2009 | 05:50 AM
86toylet's Avatar
Banned 'cause I was 4runnerchevy also banned
Upgrade your lines comming out of the tank and throw an inline High pressure pump. You can pick all this stuff up through summit racing. I would run a 3/8 high pressure line, and a 5/16 return line for the V8.
Old Apr 13, 2009 | 06:05 PM
Jfoust's Avatar
sweet thanks guys that helps a bunch on the fuel issue
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
KBar
Jul 13, 2015 06:01 PM
Coreyr384
Jul 10, 2015 11:13 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
