Domestic Swaps Chevrolet, Ford, ect
2002 4.3 into 88 4runner
Old Sep 16, 2008 | 05:47 AM
akarocket's Avatar
I am getting started with my 4.3 install. I am slowly gathering parts. The engine is a 2002 4.3 Vortec with 30000 miles. I am using a Howell engine harness and computer. Going to mate that to a TH350 and then use a Advance Adapters to the Toyota case.
I got the TH350 all done. Rebuilt with a shift kit and a 2000 RPM stall converter Going to use a Lokar shifter:
Engine looks good. Now I need to start stripping off what I won't use
Cleaned up:
Waiting for my stuff from Advance Adapters to show up. Still need to figure out how I am going to do the accessories on the front. I think I might switch to a short water pump and run a drive system similar to a street rod. Otherwise, I might just get some brackets out of the salvage yard. More updates to come.
Old Sep 17, 2008 | 10:32 PM
fillsrunner4's Avatar
Looks great That motors gonna be nice in there.
Ya I think your going to have to get another water pump in there. I dont think it will fit. You might want to look into an electric fan for the front also it will free up some space. I like the taurus fans. Im using the bigger Mark VIII but the taurus fan is small and fits perfect to the toyota radiator if your gonna use that. Theyre cheap and easy to wire not to mention 2 speed and can cool to 5000 CFM
Gives you some idea of what your gonna have for space up front. Not much. I even put my radiator in the back but thats for more than just this reason
Good luck hope to see plenty of pics
Old Sep 18, 2008 | 06:13 PM
akarocket's Avatar
Making a little bit of progress. Found accessory brackets from a 2000 Astro Van.
Before:
After:
Notice anything missing?
I think the stock pump will fit. I guess I will find out.
Old Sep 19, 2008 | 07:21 PM
Adam F's Avatar
No A/C?
Nice project. The 4.3 vortec is a peppy little motor. Pushes a little Astro van around quite well, should be nice in a Toyota.
Old Sep 20, 2008 | 11:29 AM
akarocket's Avatar
Originally Posted by Adam F
No A/C?
I cut the idler bracket off the alternator side and the A/C off the other side. Need to do that because I am changing the belt routing around.
Old Oct 1, 2008 | 11:49 PM
No A/C?
Removing the AC pump makes a nice location for the supercharger on this motor
Old Oct 5, 2008 | 05:20 AM
akarocket's Avatar
Making a little progress:
Old Oct 5, 2008 | 06:42 AM
texcat101's Avatar
Awesome project I am a little behind you in my 4.3 swap, so I will be watching.
I am looking for a 700r4 non electronic tranny, wish I could find used advanced adapters and output shaft - but not likely.
NWOR has some cool engine mounts and headers, Downey also has some good stuff.
Old Oct 5, 2008 | 12:05 PM
akarocket's Avatar
I purchased the mounts, headers, and TH350 adapter from Advanced Adapters. Find a vendor that deals with them and they can get you a hefty discount compared to their website. I went through www.rockbuggysupply.com
Excellent service!
Old Oct 5, 2008 | 01:41 PM
texcat101's Avatar
Excellent service!
Thanks rocket! I will check it out. Those items are pricey!
Old Oct 14, 2008 | 03:00 PM
akarocket's Avatar
Motor is ready to drop in. I have got everything bolted on and ready to go. I was able to remove the oil cooler adapter from the block and screw the filter straight on.
I thought the front accessories turned out pretty well :mrgreen:
Found a 150 amp alternator from a Yukon Denali. I disassembled it and had TMCO powdercoat the case. BLING BLING!
Power steering pump is a Saginaw from a 00 Chevy truck.
March underdrive pulleys.
Old Oct 14, 2008 | 03:46 PM
toy power's Avatar
very cool. i couldnt live without air conditioning though
Old Oct 14, 2008 | 06:39 PM
akarocket's Avatar
My truck lives with no doors or top from early spring to fall. I am sure there are times I will miss it.
Old Oct 14, 2008 | 06:49 PM
texcat101's Avatar
Awesome 4.3! like I said I am a little behind your timeline. Keep up the good work.
Old Oct 19, 2008 | 08:04 AM
akarocket's Avatar
Well yesterday was productive. Started at the beginning of the OU-Kansas game and finished just as Texas was putting the final butt kicking on Misery .
Had to severely tilt the engine to get it in there:
Almost looks like it belongs.
Plenty of room for a radiator and a fan.
Up tight against the firewall:
View from under:
Make sure and remove the bracket on the rear of the head for the 4.3 and the bracket that holds the clutch slave line. They will interfere with each other:
Old Oct 19, 2008 | 10:07 AM
Adam F's Avatar
That 4.3 fits VERY nicely in there.
Keep us updated. Id like to know how well it performs. What kind of HP/TQ numbers are you expecting?
Old Oct 19, 2008 | 10:43 AM
Very clean
Ide recomend getting some spark plug heat sheild wrap to go over them near the headers. I say this cause my friends gone through a few wires just cause the headers get so hot and the plugs run very close to them
Very nice
Old Oct 19, 2008 | 11:06 AM
akarocket's Avatar
I am guessing with under drive pulleys, headers, exhaust, and a custom tune somewhere around 220/270
Old Oct 19, 2008 | 11:07 AM
akarocket's Avatar
Originally Posted by fillsrunner4
Very clean
Very nice
Ya, I need to pick some of that stuff up!
Old Oct 19, 2008 | 11:10 AM
Same here!
Looks great!
