Diesel Swaps Diesel engines
OM617 inspection
Old May 21, 2012 | 07:41 PM
technojunkie's Avatar
Originally Posted by Transplanter
Be careful,the heads like to strip real easy. Mark your flywheel position before you remove it if you plan on having the Toyota match balanced.
hehe... I have a new grinder waiting just in case. Already have, and plan to.
Old May 22, 2012 | 03:06 AM
22REFORME's Avatar
a grinder? yikes man
Old May 22, 2012 | 07:27 AM
Reading on peachparts that once the head has been rounded, just grind it off. This relieves the pressure from the bolt stem, lets you remove the flywheel, and the vibration loosens the bolt sufficiently to back out with just your fingers.
These are torque-to-yield bolts, so can't (shouldn't) be reused anyway.
Old Jul 31, 2012 | 09:50 AM
OK, The truck is about to go under the knife... err ratchet. I have a couple minor repairs to make to the 4Runner to make it road worthy, then I can start extracting the 22re from the truck. I figure I will probably replace the clutch while I have it out (It only has 30k on it). Those of you who have completed the swap are you using a stock clutch or a heavy duty one? I'm considering the 1200lb Marlin crawler clutch but since I don't plan anything harder than trail driving I was wondering if it would be a good idea to upgrade.
mountainbrew
Diesel Swaps
Sep 20, 2015 07:12 AM
bhaithc
Sep 17, 2015 07:53 PM
Dobich
Sep 14, 2015 11:15 PM
VT2LAB
Sep 10, 2015 09:36 AM
Boomer8404
Sep 10, 2015 09:01 AM
