Diesel Swaps Diesel engines
93 4X4 V6 to 2L-T build thread
Old Jun 23, 2017 | 04:51 PM
  #41
kibbleking's Avatar
Thanks RBX,
My son suggested I look into getting a lift kit ?? Would that increase the distance between the oil pan and the front diff ??
Clancy
Old Jun 24, 2017 | 04:24 PM
  #42
RBX's Avatar
RBX
A suspension lift, yes, but it needs to be a bracket lift to lower the front differential, it would be cheaper to hire or rent a welder to add motor mounts honestly.
It would be very helpful if you could load some pictures of what you are doing and the issues you are having.... What is your location, there are yotoatech members all over that aew willing to help.
Get the correct oil pan, sump, and windage tray under the engine and see where you are with that. As for the transmission mount, there is an adapter sold on ebay if I recall that allows about 4" of adjustment.
Old Jun 25, 2017 | 06:23 PM
  #43
kibbleking's Avatar
Thanks Rbx,
Location is southern oregon,
I'm on the hunt for the oil pan. Made contact with a fella in Greece and a fella in Australia.
We'll see if anything turns up there. I can get one on J-P carparts for just around 260.00.
If I can't find one I may see if one of our local fab shops can do some minor mods to the one I have,
The lift kit is 189.00 and includes diff lowering brackets. Seems like a good plan. I will hunt around on Ebay
for the Trans adapter. I'm open to any and all solutions. Perhaps a combo of them will get the job done.
Clancy
Old Oct 16, 2017 | 10:04 AM
  #44
Rustbucket1990's Avatar
How's the swap progressing? Did you drop the diff, get a new pan, make new mounts or anything? I'd love to hear about it!
I seemed to have the same problem, but found if I raised the engine up about an inch, my pan clears nicely. This of course requires a body Lift, but, that's relatively easy (remove the 6bolts from the cab, and insert spacers)
Old Feb 25, 2018 | 12:18 AM
  #45
87_2LT's Avatar
Are you looking for a bell housing? I might have a spare. Oil pan off a NA market 2LT possibly too, would have to look. Is the engine a 2LT or 2LTII/2LTE?
  #46
87_2LT's Avatar
Old Mar 22, 2018 | 08:44 AM
  #47
Kadin's Avatar
Bell housing bolts
My top bolts on my bell housing are very hard to get to there is about two inches of room wondering if you had the same problem.
Old Mar 22, 2018 | 12:20 PM
  #48
Clancy hasn't been around for a while, but since the 2lt and 3l are nearly identical I might be able to help.
When I did mine, I pulled the tranny and put it all together on the ground, then put it all in at once.
Old Mar 22, 2018 | 01:44 PM
  #49
Kadin's Avatar
Rust bucket 1991
I tried that but not a lot of room . And that sucks cause I had a few questions about how he had mounted the battery’s
Old Mar 22, 2018 | 03:00 PM
  #50
Are you going to go with the stock mounting position for the battery, or put it where the air box normally goes? I swapped the air filter box and battery locations on my truck, and so far I love it. The battery is on the same side as the starter, and glow plugs. Both of us deleted our ECMs, that requires finding the wires that signal the ignition, and starter (I spliced in the main box under the hood, but if I did it again I'd go right from the ignition switch).
Old May 3, 2018 | 06:13 PM
  #51
Kadin's Avatar
Thank you
I did that and it worked great but having more problems with the fuel pump it works but isn’t getting power and I can’t think of why since it was running for the last owner
Old May 4, 2018 | 04:55 PM
  #52
Electric, or engine power?
If your engine isn't developing power, I have 2 suggestions. First, make sure the pump is pressurized to ensure proper bleeding of all injector lines. A friend and I did this on my 3L and that fixed it. Second, the fuel screw on the back of the pump can be adjusted to achieve desired power outputs. Mine seems to work backwards: it's sluggish if screwed out.
Old May 4, 2018 | 05:00 PM
  #53
Wait a second! I might have this all wrong 🤔. Are you talking about the lift pump in the tank? I Jerrry rigged mine by running a wire straight from the engine run fuse to the lift pump. To keep from blowing a line, I plumbed in a bypass before the injection pump (about 1/2 of the diameter of the main fuel lines to retain pressure).
Hope this helps!
Old May 5, 2018 | 01:26 PM
  #54
Kadin's Avatar
Yes it is the lift pump and it looks like it has already been done like that I took out the fuse and bypassed it but it still didn’t wanna work
Old May 5, 2018 | 02:29 PM
  #55
Hmmm. Try running a new wire from any wire in the truck that gets power when the key is in the run position. I chose a wire in the fuse box because it was easy to find. Simply splice into it, and power the lift pump off of that. It's Jimmy-rigged I know, but it should do it if there's power there, and the pump runs when you put external power to it.
Old May 5, 2018 | 06:55 PM
  #56
Kadin's Avatar
I got it working but stared to pour out everywhere by the stater
