Diesel Swaps Diesel engines
1st Gen P/U with OM617.951
Old Nov 18, 2011 | 09:28 PM
  #141
pyrojoe22's Avatar
So do you have to flip a switch momentarily to kill the engine?
I picked up a Chilton's today which will hopefully answer a lot of my generic questions. I found the wiring diagram, but it's pretty vague. I traced the wires for the glow plugs to the black box, but don't know what I need after the black box. I'm assuming you put a glow plug light in your dash. I have some unidentified wires, that I'll take a pic of tomorrow and post up. If you feel like I'm thread jacking, I'd be more than happy to post up in my build thread, but no one's been posting in it yet....
Old Nov 18, 2011 | 09:35 PM
  #142
truckman1966's Avatar
i took the factory harness from the glow plugs to the controller box and cut all 5 off, put ring terminals on them, attached them to a ford starter solenoid i mounted behind the headlight, and put a push button on my dash. works great and every parts store stocks a $10 solenoid for emergency repairs wherever i may be. i kinda approached this project with that mindset. i want something that is easy to replace, and something that every store stocks so that if something were to fail, i wouldn't have to wait a day or more to get the part.
Old Dec 7, 2011 | 02:42 PM
  #143
korn111685's Avatar
how did you plum everything? where is the rad? IC? is it finished?
Old Dec 7, 2011 | 03:15 PM
  #144
BrutalIntegrity's Avatar
Awsome setup!!!
Old Dec 7, 2011 | 03:38 PM
  #145
the rad is mounted in the back kinda trophy truck style angled forward, there are 2 - 1.5" pipes running all the way back to the bed where the rad is mounted and i am not running an intercooler. turbo and manifolds are stock as of yet. and yes. its been finished for about 6 months now
Old Dec 7, 2011 | 03:39 PM
  #146
Originally Posted by BrutalIntegrity
Awsome setup!!!
thanks man!
Old Dec 7, 2011 | 04:17 PM
  #147
pyrojoe22's Avatar
As far as deleting all the vacuum bs goes, how did you hook up your brakes?
Old Dec 8, 2011 | 04:06 PM
  #148
used the factory vac hose off of the yota and re-routed it straight to the vac pump. the benz does the same thing with the brakes.
Old Jan 19, 2012 | 10:18 AM
  #149
2003mikem's Avatar
Can u post a pick of your oil pan, I have read that you need to cut or trim your pan in a om617 swap ?
Or is that only with high steer ?
I am collecting parts for my 1985 4ruuner OM 617 swap
4” full spring lift…
Old Jan 19, 2012 | 10:23 AM
  #150
ChefYota4x4's Avatar
How's she runnin, Mista? lol. Hope all's well, Truckman!
Old Jan 19, 2012 | 11:32 AM
  #151
Runnin good. Been playing around in the 15 degree weather and snow and ice. fires up every morning for me. consistently getting 30+ MPG
Old Jan 19, 2012 | 11:41 AM
  #152
The lift thing is only for hi-steer. if i decide to go high steer, I will have to go for more lift too.
Old Jan 19, 2012 | 11:45 AM
  #153
We've got a bit of snow up here in northwest washington. started building a winch bumper a couple days ago and also been pricing out lockers.
Old Jan 19, 2012 | 11:56 AM
  #154
2003mikem's Avatar
so it wont hit the diff if i dont have high steer correct ?
Old Jan 19, 2012 | 03:14 PM
  #155
the pan? the objects in question are the steering center link and the lower oil pan. this has nothing to do with the front diff. mine, at full flex, misses the pan by about 2 inches.
Old Jan 19, 2012 | 04:08 PM
  #156
was digging through my photobucket album and found this pic. figured it might help you out mikem
Old Jan 20, 2012 | 04:55 AM
  #157
2003mikem's Avatar
great good to know.
Old Jan 25, 2012 | 05:49 AM
  #158
2003mikem's Avatar
If you can u take a pic form the passenger side so I can see the clearance from the side of the diff?
Old Jan 25, 2012 | 05:53 AM
  #159
I can. But let me put ita this way. I have rears up front with my axle moved fwd about 2" and it still has a couple inches of clearance
Old Jan 23, 2019 | 02:40 PM
  #160
8 freaking years
8 years since I Diesel swapped! Now it's on 35s, lockers, still 3.9 gears, still getting around 30mpg, and many many miles on the swap.
I can't believe where the time has gone. Still one of the best things I did to this truck. Cheers!
