All Other Toyota Swaps I4, I6, Lexus V8
Will the 5VZ bolt into my 3RZ equipped 97 Taco...
Old Sep 14, 2009 | 02:35 PM
project91's Avatar
Yep..the dead horse is back..go on beat him. I haven't posted in 6 months! Now I am back at the torch again...I have a 97 Taco..with a 2.7 in it. Its 4WD 5 spd...And I want the 5vz 3.4 in it. Bellhousing the same? Motor mounts? How bout tranny crossmember? The exhaust fairly easy to fab? I know I don't "technically" need the harness and ECU, but it makes it easier! I wonder if I can find the thread where I swapped in a 3. slow in place of my 22re? Yes thats what I did...just cuz I could do it. Anyway I guess thats my only question..motor mounts good? Bellhousing?
Old Sep 14, 2009 | 03:01 PM
project91's Avatar
If I could buy a 3.4 equipped Tacoma for 2 grand don't ya think I would do that? Besides I am up to the challenge.
Old Sep 15, 2009 | 12:55 AM
vital22re's Avatar
totally a bro
well.. you'd need everything under the hood and the tranny i believe. complete engine wiring harness and ecu. you cant' run a 6 cylinder motor with an ecu that was made for 4 cylinders. I got my complete 3.4 swap for 1500 so... look around at wrecking yards i'm sure you'll find something.
Old Sep 15, 2009 | 12:00 PM
project91's Avatar
So the tranny isn't compatible with the 2.7 tranny? I know I need the ECU for the 6, it just doesn't matter if ya have an auto tranny ecu or manual..I just pin the correct wires to fool it..got that under control.
Old Sep 15, 2009 | 12:39 PM
vital22re's Avatar
totally a bro
i dont' know for sure but i believe they are different.
Old Sep 15, 2009 | 01:55 PM
yodathespian87's Avatar
As far as I know you will need the engine, harness computer all the sensors and well everything under the hood and the transmission. Cause they don't match. So for all that work I would go bigger or buy a different taco. (there are some good deals out there, yes for 2 grand)
1uzRunner
63
Nov 10, 2018 03:58 PM
Pocoyota
Sep 8, 2015 02:41 PM
zz_denis
Sep 6, 2015 03:43 PM
eggens
Sep 5, 2015 12:16 AM
Aaron Logan
Sep 3, 2015 08:08 AM
