85Toymans 1994 4Runner 1UZ Build
https://www.yotatech.com/forums/f199...thread-225636/
www.northwesttoysllc.com
I thought I would share the complete build of a running and driving 1UZ I completed on our shop truck which is a 1994 4runner.
Here is the run down on what I used and what works at least for me. There are alot of ways to complete this install and not one of them I have seen is exactly the same, but everything I have done has worked out really well.
1994 LS400 1UZ with 120,000 miles.
NWT Bell housing
NWT billet steel flywheel
NWT clutch kit
NWT 1UZ block hugger headers
NWT motor mounts
NWT body spacer 1" pucks
Custom built exhaust
SC400 Non atrac throttle body
NWT aluminum radiator with a puller fan with fan shroud
NWT wiring harness
NWT transmission cross member with under belly skid plate
I have since put about 7,500 miles on the rig since the swap. This rig started out as an IFS rig and we have since swapped out to a solid front axle with duel elockers front and rear.
Hope you enjoy, and if you have any questions feel free to let me know.
Thanks,
85toyman
Product and Application Waiver
All products sold by North West Toy's,llc are sold for off-road use only. Any other use or application is the responsibility of the purchaser and/or user. Rock crawling and off-road driving is inherently dangerous activities. Some modifications will adversely affect the on-road handling characteristics of your vehicle. Some modifications and installation of certain after-market parts may under certain circumstances void your original dealer warranty. Modifications of your vehicle may create dangerous conditions, which could cause serious bodily injury or death. Buyers and users of these products hereby expressly assume all risks associated with any such modifications and use. North West Toy's,llc also recommends strongly that all products be installed by trained professionals only.
NWT Bell housing
NWT clutch kit
NWT motor mounts
NWT wiring harness
Thanks,
85toyman
Jun 1, 2021 01:51 PM
XtraCab
Apr 12, 2020 05:25 AM
Road Bull
Oct 10, 2015 04:55 PM
