All Other Toyota Swaps I4, I6, Lexus V8
22re to 7mge need some help
Old May 29, 2010 | 02:11 PM
94toy4x4fever's Avatar
Well im getting very close to doing this swap! Have read a alot on it and been throwing ideas around in my head! One thing that I need to find more info on is cooling! What radiator should I use? I was thinking the supra or toyota 3.0 radiator and (2) electric fans! If any body has any ideas let me know!
Old Jul 5, 2010 | 08:18 PM
No one has said anything on the 2 connectors that go to the transmission on a 94 toyota pickup. Im thinking about just pulling apart my 22re wire harness and reusing these wires. Does anyone see a problem with that?
Old Jul 6, 2010 | 02:45 AM
motorhead's Avatar
I reused a few plugs off the old harness myself down in that area to get backup lights and the 4wd indicator to work.
Old Jul 6, 2010 | 05:53 PM
see my truck also dosent have a cable speed O. So Im thinking just reusing these connectors and just leave them the way they were! what you think motorhead?
Old Aug 27, 2010 | 06:45 AM
  #25
I still cant figure out what wire I need to tie into my starter signal to tell the ecu im starting the engine. I have wire diagrams and everthing. If some one could point me in the right direction that would be sweet~!
Old Aug 27, 2010 | 06:48 AM
  #26
supracharged says to use a small guage black/blue on the B! connector. I dont have that wire on my B1 connector!
Old Aug 29, 2010 | 04:49 AM
  #27
motorhead's Avatar
I'm pretty sure that it's already done for you...look in the harness between the firewall and the engine, find the small black/blue and it should trace to the large one before it reaches the rubber plug at the firewall. On a side note, I ended up using the black/white ground in the plug under the hood that carries the black/yellow you use to go to battery power. Needed it to make my cel stuff work...why, I have no idea, doesn't sound like anyone else did/does.
Old Aug 29, 2010 | 10:09 AM
  #28
Yeah i figured it out yesterday after looking at the wire diagrams and testing stuff out. I have one question, how come my oil light and other light dont come on when Im fisrt starting the engine and then go off after the key has been on a while? I hooked up all the wire for guages and the guages work but the lights dont come on. I also grounded the same wire you did, thats what the wire diagram says that wire if for.
Old May 5, 2012 | 02:28 PM
  #29
streetlancer's Avatar
Any updates on this? How did it turn out?
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
