All Other Toyota Swaps I4, I6, Lexus V8
1uzfe swap into 92 toyota RV 2wd
Old Feb 28, 2015 | 11:44 AM
mtdave2's Avatar
And not a single f$ck was given. lmao! haha.. oh well I am used to talking to myself.
BTW does it not suck when you finally get some time, and the weather puts a stop to the project. this summer i plan to have a garage and a lift! would be nice have it now.
Attached Thumbnails 1uzfe swap into 92 toyota RV 2wd-11018602_10153079393697567_6746486405699416355_n.jpg
Old Feb 28, 2015 | 12:38 PM
RainSR5's Avatar
Looks great so far! Makes me want to go work on mine! Start on that wiring yet?
Old Feb 28, 2015 | 01:26 PM
mtdave2's Avatar
thanks for replying, I start wondering if anyone reads these things. Because of the weather, I am labeling wires. Since im using almost everything in the engine loom, im working on a harness.. fun! this is going to be the hardest part for me. only one way to learn it i guess.
Attached Thumbnails 1uzfe swap into 92 toyota RV 2wd-20150228_145508_zpsxdaeyu0t.jpg   1uzfe swap into 92 toyota RV 2wd-20150228_145551_zps0etd9ilx.jpg
Old Mar 15, 2015 | 05:07 PM
85toyman's Avatar
Looks good bud. I finished my 1uz swap a while back and love it.
Old May 9, 2015 | 02:30 PM
  #25
mtdave2's Avatar
so i had to do something other than wiring so, i installed a battery box, and connected the power steering completely. I even filled it with fluid and spun it up with my drill. I was amazed how much torque it took when i had someone in the cab turning the wheel. it stopped my 18 volt drill!
good news is there are no leaks, and the person turning the wheel was amazed how little effort it took. she is gona steer sooooo nice.
Attached Thumbnails 1uzfe swap into 92 toyota RV 2wd-20150405_112324_zpslazmuqdu.jpg
Old May 9, 2015 | 02:33 PM
  #26
mtdave2's Avatar
a little more progress. I did not want to try to stuff a trany cooler and an oil cooler in front of the radiator. so I stuffed this awesome cooler in the engine bay. It is a dual fluid cooler, one for the trany, the other for oil and has it own fan.
The first issue is air flow, where will the fan push the air? so I welded in a louvered deal. may help get some of the heat out of the engine bay. I'm hoping it works ok, if not I'll make a shroud funneling the air to the louvers. I get my hand up in there and there is some good airflow. we will see!
linked a video of it running, the sucker really sucks, or blows, or whatever. the odd noise is not the fan, it is the power prob i was using to power up the fan.
Attached Thumbnails 1uzfe swap into 92 toyota RV 2wd-20150419_112449_zpskkpypna8.jpg   1uzfe swap into 92 toyota RV 2wd-20150417_165934_zpss37k8pqj.jpg   1uzfe swap into 92 toyota RV 2wd-20150418_170245_zpsguhuiqfo.jpg
Old May 9, 2015 | 02:41 PM
  #27
mtdave2's Avatar
next i worked on installing the cooler lines. One fitting left to get and then I can do the final assembly of the front end stuff! The braided hoses and AN fitting are really awesome. I hope there are no leaks, but I did take my time. both oil and trany fluid have inline filters, and get ran through the cooler. I should be able to do 80 up hill in the desert and stay cool! lol
Attached Thumbnails 1uzfe swap into 92 toyota RV 2wd-20150509_143532_zpsuhowbn8o.jpg   1uzfe swap into 92 toyota RV 2wd-20150509_125225-202_zpsr3eudpw3.jpg   1uzfe swap into 92 toyota RV 2wd-20150509_125221_zpspptwspx2.jpg
Old May 9, 2015 | 02:49 PM
  #28
mtdave2's Avatar
the stock intake has a box on the bottom that there is just not room for and the angle was off just a bit, could work but i decided to build one. use a 3 inch exhaust U fitting and cut it in half, then got the angle right and welded together. drill and weld in a pile for the vacuum with a bit of brake line for the smaller tube. Little paint, and a bracket and this sucker looks great and is solid.
Attached Thumbnails 1uzfe swap into 92 toyota RV 2wd-20150427_180114_zpsetpwu3s0.jpg   1uzfe swap into 92 toyota RV 2wd-20150427_180917_zpsjy0pkno7.jpg   1uzfe swap into 92 toyota RV 2wd-20150427_191836_zpsp2lcqznn.jpg
Old May 9, 2015 | 02:51 PM
  #29
mtdave2's Avatar
more photos of the intake
Attached Thumbnails 1uzfe swap into 92 toyota RV 2wd-20150428_185226_zpse2kzlxsq.jpg   1uzfe swap into 92 toyota RV 2wd-20150428_185236_zpsfjf3kdgv.jpg
Old May 9, 2015 | 02:57 PM
  #30
mtdave2's Avatar
guess i have to get back to the wiring, I am not enjoying this part of it. :/
Attached Thumbnails 1uzfe swap into 92 toyota RV 2wd-post-7786-0-07984800-1428107511_zpsvbkrww1l.jpg
Old May 9, 2015 | 05:30 PM
  #31
RainSR5's Avatar
Looking great! Reminds me I need to get back to work on mine
Old May 9, 2015 | 05:46 PM
  #32
mtdave2's Avatar
oh, and I now know not to use tape on AN fittings.....
Old May 9, 2015 | 06:22 PM
  #33
skypilot's Avatar
Now that is a lot of fussy fab work!
Old May 10, 2015 | 06:01 PM
  #34
mtdave2's Avatar
sigh, you are telling me.. was really fun for a while but i need to be done! doesnt help when you have to redo stuff cuz you are dumb lol
Old May 10, 2015 | 06:02 PM
  #35
mtdave2's Avatar
did get some of wiring hooked up. was able to turn the motor over with the key. guess that is a mile stone huh?
Old May 13, 2015 | 02:32 PM
  #36
mtdave2's Avatar
waiting on one little fitting! then I can install the radiator and button up the front end. guess ill keep working on wiring. The dash is half done, I have discovered several wires that I will have to run because the toyota did not have them!
Old May 24, 2015 | 06:59 PM
  #37
mtdave2's Avatar
so, the radiator is not installed, and the trany lines are open but I wanted to start this thing. freaking runs and sounds like a dragster! tomorrow ill get the radiator in and finish up some wiring. still lots of work to do but man what a feeling to fire it up!
sorry for the poor quality of the the first one, I have no idea why that camera did such a crappy job!
the second one is better, and yes i was expecting the trany fluid. My buddy was not lol.
the first fire up
the second
love how smooth it runs, and does not move an inch!
Old May 26, 2015 | 07:58 PM
  #38
mtdave2's Avatar
Old May 27, 2015 | 02:47 PM
  #39
mtdave2's Avatar
lol, and the number of Fks given........0
Old Jun 17, 2015 | 01:50 PM
  #40
defrag4's Avatar
amazing swap! my friend told me his neighbor was swapping his 3.0L for 1UZ, i couldnt believe it, googled around a bit and here you are! impressive fab skills and determination!
looks like its almost time to hit road and do some camping!
