All Other Toyota Swaps I4, I6, Lexus V8
1UZ to 86 T4R 22re Dual Case 4x4
Old Jun 13, 2013 | 11:32 AM
  #61
yotasavg's Avatar
Great swap, about to finally get going on mine as well. I'm using the auto too, but I'll be going 2wd for phase 1, no AC and hopefully keeping cruise control. @Toyminator, did you keep cruise control?
Old Jun 13, 2013 | 09:36 PM
  #62
tyes's Avatar
lollol
Old Jun 14, 2013 | 05:15 AM
  #63
toyminator2000's Avatar
No because mine is only used off road but it wouldn't be too hard to include it. Just need to find a place under the hood of the Toyota to put it.
Old Jun 15, 2013 | 06:54 AM
  #64
jmswltn's Avatar
So the inch worm adapter isn't available in 21 spline any more, when did you order it?
I want to get it but would rather use the 21 spline case as i have 2 of them
They show the plate in the picture it should come with it
Old Jun 15, 2013 | 07:47 AM
  #65
jmswltn's Avatar
Do you have way to change the 3 bolt out put in the Lexus Trans?
Old Jun 15, 2013 | 09:36 AM
  #66
tyes's Avatar
[QUOTE=jmswltn;52
Old Jun 19, 2013 | 07:37 PM
  #67
tyes's Avatar
heres a little update:
plugs welded for the port on the AC compressor
[IMG][/IMG]
Old Jun 19, 2013 | 07:40 PM
  #68
tyes's Avatar
this is the fuel pump swap. the one on the right is the SC400 and a lot smaller from the 22re. not sure why, but it is what it is...
[IMG][/IMG]
Old Jun 19, 2013 | 07:43 PM
  #69
tyes's Avatar
qerer
Old Jun 19, 2013 | 08:29 PM
  #70
tyes's Avatar
ghygh
Old Jun 26, 2013 | 08:34 AM
  #71
tyes's Avatar
lolol
Old Jun 27, 2013 | 06:12 PM
  #72
tyes's Avatar
some pics...
Old Jun 27, 2013 | 06:13 PM
  #73
tyes's Avatar
ploki
Old Jun 27, 2013 | 06:19 PM
  #74
tyes's Avatar
was gonna
Old Jun 27, 2013 | 06:25 PM
  #75
tyes's Avatar
finished the radi
Old Jul 2, 2013 | 09:31 PM
  #76
tyes's Avatar
this exhaust i
Old Jul 2, 2013 | 09:35 PM
  #77
tyes's Avatar
was wondering if there was a difference in the intake elbow for the air box from a ls400 vs sc400? cant seem to fit this sc400 air box like others had! or is there a special mod?
Old Jul 4, 2013 | 02:52 PM
  #78
Most eliminate the hard plastic duct piece coming right off the throttle body.
Old Jul 4, 2013 | 06:25 PM
  #79
Aznwolf118's Avatar
Grab a rubber factory intake gasket off a old rx7, it's shorter and you can almost make it fit, between the maf and tube. Most of the cutting will be done to the factory air box, the ref just wants to see that the maf/map is working and behind the air box.
The only difference between the ls and sc intake tub is the size of the silencer under it. It took me 2 days at the pick and pulls and a day mounting both to realize that.
By the way the ref at Fairfield just passed a 80 p/u with a obd2 1uz swap.
Old Jul 5, 2013 | 10:22 PM
  #80
tyes's Avatar
[QUOTE=toyminator
