What is the name of the switch on the front diff?
I think that its called transfer indicator switch or something like that. I could be wrong but isnt it the same switch that is on the transfer case??
try this
http://www.toyodiy.com/parts/q.html
try this
On my swap, ORS wired the indicator wire to the transfer case. I can't help you much, unfortunately, since I didn't build my harness, but it does go to show you don't need to wire in the indicator on the diff. As for the vacuum to the vsv, check out my thread...I may have a clear picture of the routing, and I used the original vsv's for my 3.0.
https://www.yotatech.com/forums/f160...eknraj-161816/
Sorry, I'd post the pictures if I could, but work computer blocks photobucket.
Yeah which I'nm not worried if it says that its in 4x4 or not, cause I would have just locked it in and kinda would remember that. I don't need all those lights telling me what I'm doing.
The wiring for this is really easy actually. The power for the system comes through the bulb, so you do need the 4x4 dash light in the circuit. The wire from the bulb goes to the 4x4 switch, then a wire from the 4x4 switch goes to the switch on the front diff, then the other wire on the diff switch goes to ground. At the join of the 4x4 switch to diff switch, a third wire goes to the coil of the add relay. Output of the relay goes to the 2wd and 4wd vsv's and thats about it.
Short the wires together for the diff switch and you dont need to connect the ecu.
Basically the 4wd shifter is the only switch now and it activates the relay.
If this makes zero sense, I'll search and post the schematic.
UK runner, Can you post the schematic that you mentioned? I have an ORS harness but it doesn't have the plug for the diff and I want to have my ADD fully operational. Also, where do you get the vacuum source from on the 3.4?
I can't believe I missed this in my research. I didn't think the ECU had anything to do with auto hubs. I guess the VSV feeds a status back to the ECU?
Does that mean if the 93 chassis had auto hubs that the donor ECU must come from vehicle with same?
thanks
thanks
I dont think my ecu came from a vehicle with auto hubs because when I connected my ecu, nothing happened. I removed the connection to the switch on the diff (shorted it) and now the 4x4 works perfectly.
jerusry
Oct 19, 2015 05:28 PM
scottyg486
Jul 19, 2015 05:34 PM
TokyoD23
Jul 12, 2015 06:01 AM
crashburnoveride
Jul 10, 2015 06:39 AM
