Vapor pressure sensor, VC
Old May 4, 2012 | 12:00 PM
sacredmagic's Avatar
Im still fighting the throttle by wire and have come to the conclusion that my missing vapor pressure sensor is the cause for my problem. The wires for the vps come through the firewall on connector ii4 (2002 4runner), but have no mate within the cab because there was no vps on my 92, is there anyway to trick the ecu or otherwise bypass the vapor pressure sensor? Thanks in advance Ed.
Old May 4, 2012 | 10:09 PM
spinyard's Avatar
https://www.yotatech.com/attachments...question-8.jpg
gonna have to add it to your tank and wire it not too hard....
Old May 5, 2012 | 06:15 AM
Where ya get the sensor? How did ya mount it, just drill a hole and epoxy it?
Old May 5, 2012 | 08:08 AM
spinyard's Avatar
the way it mounts is sort of strange you need a piece that is on the fuel tank that the vps clips onto. Best bet would be to find one in a junkyard then you just cut a hole in your tank and mount it. You can buy the vps on ebay but you'll have a hard time mounting it without the piece that actually attached to the tank ...
Old May 5, 2012 | 02:48 PM
Im thinking about getting the sensor and hooking it up but not doing the tank mod.......no pressure =no vacuum switching right?
raptor510
Aug 19, 2015 02:15 PM
rjtrials
Aug 6, 2015 07:25 PM
calderp
Jul 27, 2015 09:58 AM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
