Vacuum Disconnect Differential after swap
Old Sep 25, 2010 | 11:17 AM
ColoradoToy91's Avatar
I removed the switches and vacuum tank and have installed manual hubs on the front. I know you can open the diff up and move the shift collar over and use a hose clamp to lock it.
I would like to know which vacuum line coming out of the diff to hook up directly to a vacuum source to have the differential locked all the time. Any help would be appreciated.
Old Sep 25, 2010 | 11:14 PM
theMonch's Avatar
I'm definetly not an ADD expert, but the '97 T100 I acquired for the motor for my 3.4 swap only had one vacuum line coming from the diff. Since the PO that I got it from had removed all the VSV stuff, I simply connected that line to manifold vacuum and it locked the shafts.
Does your diff have more than one line coming from it?
Old Sep 26, 2010 | 01:26 PM
toyota4x4907's Avatar
When you're facing it, should be the one on the left.
Old Sep 27, 2010 | 06:10 PM
thefatkid's Avatar
Are you still in Castle Rock?
Old Sep 28, 2010 | 07:39 AM
I am up in Greeley for school, but I go down on the occasion. Harness worked great btw. The only thing left on the swap is the exhaust and swapping my hubs out and hooking everything up.
Thanks again for the wiring harness and the advice! If I ever go to a supercharger I will prolly be talking to you about it and look at yours
Old Sep 28, 2010 | 08:18 AM
hamish_18's Avatar
just suck on one of the hoses haha. If it engages the splined shaft then you know you sucked on the right hose. If not then suck on the other one. When the shift fork moves, you will feel a release of vacuum. DON"T ask me how I know this ROFL. but then as long as the other hose doesn't ever get vacuum you should be fine. Unless it rattles itself loose or something.
smthwsn357
May 1, 2024 07:28 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jgwerth
Jul 16, 2015 03:23 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
TokyoD23
Jul 12, 2015 06:01 AM
