Using a 2wd 3.4 harness
I should probably start in the build section but I bought a 93 4runner auto for 700 stones that has a light bottom end knock, I priced rebuilding it and said forget it.
I bought a 3.4 with harness complete with 119K on it for 300 bucks 4runner was hit in the side hard so it was a total loss.
My question I'm using a 2wd harness are the 4wd plugs going to be absent for the t-case or are they taped to the harness underneath. The motor is being delivered to my garage today and I didn't pull it or even think to check.
I already have a 97 4wd t100 computer so I told them to leave the ecu behind. I realized this error this morning so if Ineed to get a harnesss for a 4wd its going to suck because I'll have to go to the junk yard and pull it myself.
Homework oh yes.... spent 5 hrs in 2 nights researching, found an 85 straight axle complete in carolina for 300. so next project and I haven't even signed the title.
I own an auto repair shop so this is all second nature. First setback junkyard pulled a 94 gold yota on accident I almost said leave it but asked for them to check one more time and sure enough no extra charge and a 97 2wd here I come...
I used a 3.4 auto 2wd harness for my swap. I'm using a manual trans though. There should only be 5 wires in the transfer case. 3 for the speedometer( if its electronic of course) and 2 for the 4x4 indicator light. If you can get it running you can figure these simple ones out.
Good luck and welcome to Yotatech
Pedalpwr27
Aug 13, 2015 06:37 AM
WellsR
12
Jul 31, 2015 03:27 PM
WTB[MidWest]: Looking for 5spd harness, front axle- 1990 truck
dfarr67
Jul 30, 2015 07:08 AM
