repinning auto harness to manual. Can it be done?
Old Jun 14, 2010 | 02:29 PM
yotaman's Avatar
Originally Posted by mechaniman
is your truck a 92, meaning it didnt come stock with an OBD2 port. you should just hide your OBD2 port, pull the bulb out of your check engine light, and let them do the emissions test as a 1992 . that way they just put it on the dyno and let the sniffer do the work and bypass all the OBD2 stuff.
He is in Cali if I remember correctly. They have all kinds of special restrictions there.
When they do an emission test in most states they turn the ignition on (to ACC) to make sure the check engine light comes on then goes off. So pulling the bulb will only make you fail right off the bat.
You can pass emissions with the check engine on in most states, you just have to figure out how much the state wants (in $$$) to allow you to do so. Here they want you to spend $450.00 before they allow you to pass.
Old Jun 14, 2010 | 02:55 PM
84Prerunner's Avatar
what is there to repin? the manual ECU should plug right into the auto wiring harness right? might have to move a few wires around as far as clutch safety switch but what am i missing?
Old Jun 14, 2010 | 03:10 PM
yotaman's Avatar
96 and 97 plugs are different for auto and manual ECU's.
98 and 99 use's the same plugs and wiring combos for both auto and manual ECU's.
Old Jun 14, 2010 | 03:14 PM
from my understanding a 98 manual ECU will plug into a 97 auto harness, is that not correct?
Old Jun 14, 2010 | 03:18 PM
  #25
yotaman's Avatar
The plugs are the same but I can't tell you if the wiring is the same. You'll need to pull the wiring diagrams and check every wire to make sure it's in the correct place.
I do know for sure that a 1997 AUTO ECU will NOT work on a 1998 AUTO WIRING HARNESS. The plugs are the same but the wires are in different places.
Old Jun 14, 2010 | 03:34 PM
  #26
ok that is the info i was looking for. thank you!
Old Jun 14, 2010 | 06:00 PM
  #27
dntsdad's Avatar
greg thanks for your info. For those of you that dont know, this dude knows his stuff!!!
I am being like a girl on this as i cannot for the life of me make up my mind whether to go back to manual or stay auto.
Going manual is just about impossible and make the smog a simple task. Staying auto makes smog easier, much easier since its already done and state approved, but I really, really want to go back to manual.
Old Jun 15, 2010 | 07:04 AM
  #28
dem0nk1d's Avatar
if you already got bar'd on the truck the transmission shouldn't matter. the hard work is already done. the only thing now that makes up for smog is the engine not trans. don't be fooled. like i said the hard work is been done.. just make sure you don't throw codes, and you should be set.
also you should have smogged your truck at the ref. my buddy suggest that i do this. get it all done in one shot.
Old Jun 15, 2010 | 01:42 PM
  #29
dntsdad's Avatar
I dont think that this is correct. The motor and trans share the same ECm so any adjustment (swapping out) of the ECM would need another BAR visit and approval from what I can tell. I have been too lazy to get over there but I am almost certain of it. The BAR sticker clearly states that I have an auto:
Also, in my case, altering the transmission by going to manual would also mean altering the OBD2 exhaust since it will never fit in the with the shift fork in the way.
SAying all that, I really do not know what the hell to do to make everything legal and simple for smog rather than keep the auto.
Also, the ref does not smog your vehicle. he only inspects it for all the proper equipment that the donor vehicle requires. Its a 45 minute wait at the most while he pulls up the info from AllData or something and then checks everything off. A sniffer was never used and never hooked up to a smog machine. He never even accessed my OBD2 port because there is no way he could have found it without asking, which he never did and I was watching him the whole time. Mine is in the glovebox and he never got in there.
Old Jun 15, 2010 | 01:46 PM
  #30
vital22re's Avatar
totally a bro
Man that is tricky... Thank God I live in washington.
Old Jun 15, 2010 | 01:49 PM
  #31
dem0nk1d's Avatar
strange. head to the smog only place and ask them about the transmission issue.
Old Jun 15, 2010 | 04:08 PM
  #32
i know the stock plate on the firewall also list what trans is in the vehicle stock, that never stopped anyone from doing trans swaps.
so your truck has still never been smogged with the 3.4 in it?
Old Jun 20, 2010 | 09:07 AM
  #33
dntsdad's Avatar
No waiting for the renewal from the DMV because a smog is expensive and only is good for 90 days.Also, since I am changing back to manual that will require a new visit to the BAR
Old Jun 20, 2010 | 09:12 AM
  #34
dntsdad's Avatar
Score!!!
Purchased a 95.5 3.4 manual 4x4 ECM yesterday for $50 with the plugs and a few inches of wire still intact. That will help immensely in matching everything up to my auto harness.
Also, he had the same configuration but for an 03 as well for $50 if anyone is interested.
Anyone have TIS access right now or a overall wiring diagram for a 95.5 Tacoma.
If so dntsdad@comcast.net
thanks
Old Aug 28, 2010 | 04:33 PM
  #35
toyotanick's Avatar
hey guys. i am in the same boat! i have a 1990 p/u with a manual 5 speed and cant for the life of me find a manual ecu with or without the harness to match up to my 1996 4runner 4x4 that i pulled the engine out of. i dont want to mess with this automatic crap! if n e one could look around in the area for me that would be extremely appreciated!!!
Old Aug 29, 2010 | 07:02 AM
  #36
dntsdad's Avatar
Toyotanick
I have already done this whole process of repinning the harness to a manual since the last post in this thread.
My current progress picks up on post 244 of my build thread. I repinned the auto harness that i had, and bought a 97 manual ECM, and then matched everything up. Really wasn't that difficult in retrospect.
I have a manual ECM for $50 if you want it. Its from a 95.5 Tacoma.
Old Aug 29, 2010 | 07:53 PM
  #37
toyotanick's Avatar
ok so my harness can be used with that ecu is what you are saying. and it is worth it to go with a manual ecu also. if so then i have no choice than to purchase this from you!
Old Aug 29, 2010 | 08:09 PM
  #38
toyotanick's Avatar
another thing, just like my automatic ecu, this ecu also has 4 plugins but my harness only has 3. haha if you could tell me why or what the 4th one is that would be awesome!
Old Aug 30, 2010 | 05:28 AM
  #39
dntsdad's Avatar
what year harness do you have again?
Old Aug 30, 2010 | 03:16 PM
  #40
toyotanick's Avatar
1996 4RUNNER. i dont remember if it was late or early 96 though
