Need A/C help, nothing has fixed it! 3.4 swap
Old Aug 29, 2012 | 07:18 AM
Replicant's Avatar
Ok, I will check those two out tonight. I have moved the valve both directions and it doesnt seem to effect it much at all. Kinda weird, it should raise the vent temps when open shouldnt it?
Old Aug 29, 2012 | 07:29 AM
NytWolf's Avatar
Yes, opening the valve should raise the vent temperature quite a bit. If it doesn't affect it much, it could be stuck partially open.
Old Aug 31, 2012 | 08:54 AM
Replicant's Avatar
I guess I am probably going to have to bite the bullet and let someone who knows more about A/C than myself look at it. I made sure the valve was closed. Sprayed water on condensor, no change in temps. Felt the lines, the low side was normal, high side was hot. Still only blowing about 70* at vents (ambient is 100*). Im not sure what else is left?
Old Aug 31, 2012 | 10:49 AM
NytWolf's Avatar
Was there oil added to the system before recharging? If so, how much?
Too much oil can affect the efficiency of cooling. Overcharge or undercharged amounts of refrigerant can also affect the efficiency.
Old Aug 31, 2012 | 11:58 AM
  #25
Replicant's Avatar
Yes, I added some oil when I put the compressor on. I dont remember exactly how much but I think it was like 3 or 4 ounces?
Old Sep 1, 2012 | 01:26 PM
  #26
vasinvictor's Avatar
I'm still leaning toward my suggestion that the heater valve is partially stuck open somehow. Everything about your AC sounds fine. You should have cold air. Any way you could have hooked up a heater hose the wrong way?
Old Sep 1, 2012 | 02:17 PM
  #27
Replicant's Avatar
Its possible the heater hoses are the wrong way. What effect would that have on the engine, because other than the A/C everything runs perfectly. Driveability is fine. Does anyone perhaps have pictures of how the 3.4 heater hoses go? I searched but couldnt find any clear pictures.
MO transplant
Apr 23, 2023 11:58 AM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
94whiterunner
Jul 12, 2015 07:15 PM
bryan34w
Jul 6, 2015 05:53 PM
