guys with working AC, do you have a clicking noise?
Old Jun 13, 2012 | 05:58 PM
QuickSilver74's Avatar
i wired up my AC with the sticky on here (the updated one) when i have my AC running and i am coming to a stop with the brakes applied i get a clicking noise from behind the glove box. it will go away if i turn the ac off when it starts making the noise and as far as i know it doesnt ever make the noise other than when i am stopping. any idea what it might be?
Old Jun 14, 2012 | 04:35 AM
vasinvictor's Avatar
Does your compressor cycle on and off when the clicking occurs?
Old Jun 14, 2012 | 05:46 AM
93NMyota's Avatar
Mine does that sometimes and I don't know if quicksilvers is the same but my compressor does cycle on and off when that happens, I know i saw it somewhere on here but i was curious about that adjustment behind the glove??
Old Jun 14, 2012 | 03:20 PM
Discombobulated's Avatar
Mine clicks under dash when it cycles and I only notice it when I stop but I listened real careful while driving and it still does it I think from road noise, engine noise it drowns it out and when you stop you can hear it better.
Old Jun 14, 2012 | 03:30 PM
I guess I should have said mine makes no audible clicking that I've ever heard.
Old Jun 15, 2012 | 02:32 PM
i will look for the adjustment for it and see if that changes anything. does anyone have a pic or write up of how to adjust it?
Old Jun 15, 2012 | 07:39 PM
technojunkie's Avatar
I'm not sure about the v-6 but the 22re amplifier has a knob that sets a cut out rpm. It works with the idle-up system to keep the a/c from running at too low an rpm. It's also possible you have too little or too much refrigerant and the pressure switch is cycling the compressor relay.
slider417
Jun 22, 2015 10:18 AM
UKMyers
11
Jun 24, 2002 05:41 AM
94 First Responder
May 31, 2002 09:07 PM
