88 xtra cab 96 3.4 swap
Old Apr 25, 2014 | 09:45 AM
chasintail's Avatar
Well I has begun, picked up and 88 xtra cab 3.0 with no motor for $400 bucks. sourced a 96 m/t 3.4 out of 4runner with harness evap and a few other things, only thing I'm missing so far is mass air and ecm. First thing to this weekend is wiring harness and compression test also order gaskets and seals, timming belt and water pump. I think I have read all the 3.4 swap threads.. only question so far is how many are running the rear 02 vs bypassing it ? will get some pics of the mess tomorrow.
Old Apr 25, 2014 | 09:49 AM
travisamorgan's Avatar
I am bypassesing it and only code I have is for the heater circuit. I put in a 15ohm resistor and you need a 12.
If ypu search on here youll find out how others have done it.
Old May 2, 2014 | 09:30 AM
chasintail's Avatar
Ok folks, timing belt, water pump and all leaking gaskets are do.
wiring harness complete, going to toss it in tomorrow.
Question is has anyone ran the 3.0 clutch and pressure plate on the 3.4 fly wheel ? I do not have a 3.0 flywheel..
Old May 2, 2014 | 12:28 PM
SacRunner's Avatar
I could be wrong here, but I was under the impression that the 3.4 clutch and flywheel is larger than that of the 3.0, so it may not work and I haven't heard of anyone trying to mix and match pieces.
Old May 2, 2014 | 01:13 PM
JasonYota's Avatar
Don't mix match clutch parts. Your 3.4 already has a flywheel correct? Get it resurfaced and buy a clutch kit for a 3.4. But you have to use a throw out bearing for a 3.0
Old May 2, 2014 | 02:57 PM
chasintail's Avatar
Got it ! Thanks guys, heading to the pull a save yard now for a clutch fork. Just noticed the " box o parts " the guy gave me didn't have one.
Old May 3, 2014 | 07:27 AM
chasintail's Avatar
Have not do to much with Toyota drive train , can you pull the the clutch fork out with the motor still bolted up ?
Old May 3, 2014 | 06:20 PM
slacker's Avatar
nope
Old May 17, 2014 | 09:30 PM
chasintail's Avatar
Alright, found clutch fork and power steering lines. Also swapped pan and pickup, apon installation of the motor I had to grind off the little "pins" on the motor mounts to work with ones on the block. Got one mount bolted in and the left side does not line up seems to need to go down 3\8" and forward the same Anyone else see this ? Hoping the frame is not bent or something..
Old May 18, 2014 | 06:48 AM
JasonYota's Avatar
If your talking about the rubber mount you could try lining it up with a screwdriver, pry bar etc.
Old May 18, 2014 | 08:07 PM
chasintail's Avatar
Yes the rubber mount, I have indeed tried a line up bar , screwdriver and pry bar. Also have swapped mounts side for side. Just doesn't wanna go where I need it, guess I need to get a photo bucket account and post a pic.
Old May 19, 2014 | 03:13 AM
JasonYota's Avatar
I didn't see where you mentioned it, you are using 3.0 motor mounts correct?
Old May 19, 2014 | 05:30 AM
chasintail's Avatar
Yes sir, 3.0 mounts. Tried the 3.4 ones also just trying to see if something would work..
Old May 19, 2014 | 06:08 PM
chasintail's Avatar
OK, finally sat back and looked at everything and noticed the lower rear portion of of the left hand mount on the frame was bent up. Causing the motor mount to hang up, guess working on it after work in the dark doesn't help much... Trying to mock up the exhaust tomorrow.
Old May 22, 2014 | 05:33 PM
chasintail's Avatar
Man, after going through the EDW I think I have everything. One question I didn't end up using any wires from connector II1 just from II3 , also E8 , and the two body plugs from the truck. Just to clarify donor is 96 runner M/T
Old May 23, 2014 | 08:51 AM
SacRunner's Avatar
Right.
The only wire I used from II1 was the R-Y wire at pin 9 for the ABS ECU "TS" signal (but I moved it to an unused spot on II3), since I kept the ABS setup on my 4Runner. My donor was a 96/97 4Runner 4x4 A/T (same pin outs) that I converted the engine harness to M/T as part of the swap.
Old May 23, 2014 | 10:50 AM
chasintail's Avatar
Good deal ! Thanks man ! just finishing my exhaust and going to hopefully start it up Saturday..
Old Jun 4, 2014 | 09:13 AM
chasintail's Avatar
So, got it to fire up. however it kicks back a few times while cranking and when its running is very rich. still have to finish the exhaust and get a different upper radiator hose, other than that good to go.. Any tips on the rich condition ??
Old Jun 4, 2014 | 09:16 AM
JasonYota's Avatar
Have all the sensors hooked up? What's codes is it showing?
Old Jun 5, 2014 | 09:21 AM
chasintail's Avatar
I do have everything except the rear o2 and trans plugs. no codes or cel.. I'M stumped !
