88 pickup 5vzfe swap
Old Aug 24, 2010 | 03:39 PM
hamish_18's Avatar
wow that mount is way different than mine. my 90's 3.0 mounts almost look the same as the stock 3.4's...
Old Aug 24, 2010 | 04:49 PM
RompKing282's Avatar
i think im going to find some small spacers to put on the 2 lower bolts on the a/c bracket
Old Aug 24, 2010 | 05:04 PM
dntsdad's Avatar
I had to clearance mine too with a die grinder. Pictures are in my thread.
Old Aug 24, 2010 | 06:19 PM
dodahman's Avatar
ac bracket
I am in the process of swapping a 3.4 into my '89 pickup. My A/C bracket slid under that tab and the bolt for that particular tab hole was longer than the rest of the mounts.
Old Aug 25, 2010 | 10:40 PM
  #25
next i want to run a fuel line to the other side.. how do most people do it?
Old Aug 26, 2010 | 05:25 AM
  #26
Trebor's Avatar
Stay on the same side and bend it going on top of the frame rail. Then flip the line on the back of the motor. It is easy and works great.
Old Aug 26, 2010 | 03:15 PM
  #27
got that done! what can i do now to get my motor ready to drop in? im waiting on the dipstick adapter piece that i forgot to order
Old Aug 27, 2010 | 05:38 AM
  #28
Trebor's Avatar
What clutch are you useing.
Old Aug 29, 2010 | 08:30 AM
  #29
a 3.4 clutch i got a grip force one off of ebay. its a stage 3 racing clutch. i figured if im going to spend the money get somthing that will last
Old Sep 2, 2010 | 08:20 AM
  #30
the motor is going in today!!!
Old Sep 2, 2010 | 04:52 PM
  #31
false alarm.. i have to get a new engine harness.. i was told my 01 4runner engine wont work . so i have to get a new engine harness and ecu/ecm and then ill send it off to toyonlyswaps. until then ill be redoing my interior. and getting everything else together.. i will post pics
Old Sep 2, 2010 | 05:24 PM
  #32
the truck
pulling the 3.slow
Old Sep 2, 2010 | 05:26 PM
  #33
picked up fenders and a fiberglass hood.
Old Sep 2, 2010 | 06:45 PM
  #34
mbomberz1's Avatar
Nice truck! I want to do the 3.4 to mine so bad. Just need to figure out where i can keep a wrecked truck for a while..
Good to see another 88 pickup around that is getting a 3.4, was hoping for a thread like this! Keep the info coming about weird quirks revolving around the 88 and your swap, had no idea about those motor mount differences. Here is mine, 3.0 for now!
What do you have planned for after the swap? got some more clearance with those fenders!
Old Sep 2, 2010 | 07:04 PM
  #35
nice truck! looks exactly like mine!
after the swap im going to start working on a LT kit with usable 4x4. deavers in the rear with a small bed cage. i dont want to get fiberglass in the rear, i think gen2s look retarded with glass in the rear. i once saw a guy that pulled his bed sides and thats what i want to try todo just to clear my 33s.in my dreams i plan on putting a turbo on it.ha
what do you have done to your 88??
Old Sep 2, 2010 | 07:14 PM
  #36
mbomberz1's Avatar
Sounds like a good plan, i have not seen too many of these with fiberglass in the rear. I agree about it looking a little silly. Seeing those pulled out a bit tho would be cool.
I have not done much to mine, yet. Painted it myself a few years ago the stock color and rebuilt the 3.0 at 150k. Just a 2inch Body lift, wheels, tires, exhaust.. headers soon. were supposed to be here about 2 months ago but im stilll waiting on them so its just cat back for now. Just put a lineX bedliner which i love a lot more than i expected. I had it stock for the last 8 years, then just this year decided to spend some cash on it instead of trying to buy a newer tacoma. The 3.4 swap sounds awesome. Id love to do a SC at the same time, but i dont have any space to do it right now which is a bummer.
That long travel kit sounds like it should be a nice adventure. I imagine after you get the 3.4 all settled that should be a walk in the park! Everyone says SAS it but i think that the LT kit would be just as much fun
Old Sep 2, 2010 | 07:25 PM
  #37
ya if i was more of a wheeler id SAS it. but i do more high speed stuff. and it will be used as a chase truck when i race long races.
mine has stock wheels, painted black w/ 33s.
tube front and rear bumpers.
my seats and door panels are being done in black and grey.
i put some procomp shocks on a few years back.
sound system. 2 12' subs, 2 6 by 9s, 2 4s, alpine head unit.
cut bed sides
HIDs w/ projector housings.
i cant think of anything else right now.ha
im always doing somthing to this damn thing. since i cant get the motor in im painting all of my interior pieces black. i want to build a center console that also goes around the shifters. any ideas?? or examples?
Old Sep 6, 2010 | 02:29 PM
  #38
theMonch's Avatar
Sounds familiar
I just had this same problem with my '88 4runner 3.0 swap. I ground off the 3/16 (thinkness of the motor mount) on the A/C bracket's lower bolt hole from behind and used 2-3 washers on the top hole to sandwich it in there.
So the lower bolt will go through the bracket first, them through the motor mount and into the block. The upper bolt will go through the A/C bracket, then through 2-3 washers, then through the motor mount and into the block.
Just a note as well, my setup did not use the lower rear bolt of the motor mount. So when you are done, you will have three bolts holding the mount to the block. (same amount as the 3.4 used, but different holes)
You want to make sure that the A/C bracket is sitting against the block properly when you are finished, because if you don't it throws off the belt alignment with the crank pulley. I learned this the hard way.
Here is my build thread that should be quite similar to what you are doing since they are both '88 3.0's.
https://www.yotatech.com/forums/f160...-speed-207371/
Old Sep 12, 2010 | 09:49 AM
  #39
mbomberz1's Avatar
So any updates?? More pictures!! Hows it coming
Old Sep 15, 2010 | 05:04 PM
  #40
sorry havent had much time to work on the truck. ive been busy but yesterday i sent my harness and stuff to toyonlyswaps and it will be done in 3 weeks! in the mean time ill be getting my interior back together! as soon as i start putting stuff in ill get some pics for you guys!
