5vz 3.4 v6 wiring harness
I need someone to point me in the right direction
I have a 97 5vz 3.4 v6 engine and automatic trans. The plan is to build a buggy around that
- so i need to find someone that can take the factory harness strip it down to just the essentials to make the engine run.
-or purchase the harness i need like the ORS stand-alone buggy harness.
in my opinion, its not worth the hassle of taking a bunch of stuff out of the harness. Just secure the plugs your not going to use. Your using the auto trans, so most of the plugs will get used anyway. I also wouldn't wory about using a stand alone harness, You will ahve to add a couple of realys, but nothing hard, if you have the wiring diagram for the 97, it will tell you right where everything needs to be, as well as the fuse size for the power to the relays.
hey if you know where i can find a wiring harness for the 3.4 plz let me know. ive gotta 3.4 waiting to get put in but i dont have the harness i was told i needed. i have the 5 speed tranny. do i still need the wiring harness for the 3.4??
Thanks,
Scott
Thanks,
Scott
pplusent
Sep 18, 2018 10:02 PM
FS[SouthEast]: 1992 4Runner with 3.4 5speed $2000
sphealy
Sep 3, 2015 07:55 PM
