3.4 ultimate build
3.4 ultimate build
Alright so I have searched and can't find a good answer.
I am debating building a 5vz or a 1uz, I want to know what the ultimate 3.4 would be? Like superchaged, what pully size, 7th kit? School me on what would be a good build.
Also I want an auto a340f? I forget what the better auto is. And the reason I want to go auto is I'm lazy and I think auto is better. I had a line on a 1uz but it fell through, so back to the 3.4 idea..
well... there is not replacement for displacement. Having said that... a supercharged 3.4 is nice... but a supercharged 1uz.... heaven. It all depends on your skill as well. How much time you have
how much money you have and if you have the tools.
My fab skills are novice at best I have the itch to learn and people to teach me, but I know either motor will be work.
I guess to me either way will just be money, I'll be rebuilding wireharness, motormounts, and all the odds and ends with a motor swap. But would I put more hp/tq down with a mildly built 3.4 or even a fully built 3.4 compared to a built 1uz? And it would be going in my runner so weight would be a small concern. Also I say motor mounts because I want to raise the motor to have better clearance of my 3link. To me a 3.4 would probably be easier and lest cost effective then the v8, but then again when I keep running everything in my mind it always says both will be equal work just depends on how much money I wanna throw down for the motor.
Well in this case I highly recomend that you read through all the write ups in the moter swap section here. I know that RMA has done a couple of the 1uz and has great write ups on his work. There is also a whole section that is just for the 3.4 swap.
I have read slot of build threads rma is awesome at his work, do you or anyone know how much hp/tq a supercharged 3.4 with headers and stuff pushes compared to a stock 4.0 with only headers pushes? And maybe a weight comparison?
Also any info on the auto tranny? What is prefered I have read that if I went 1uz using the auto there are $$$$ adapters to fit dual cases or I can get a a340f? And swap the internals out with some fabbing and get it to work. Or I can just get the 3.4 with that auto and be happy.. Idk
foampile
Dec 18, 2022 01:29 PM
Jayboy74
10
Dec 21, 2021 08:27 AM
LosPatosDelSur
23
Mar 12, 2021 03:08 AM
pplusent
Sep 18, 2018 10:02 PM
ashersullivan88yota
Aug 19, 2015 06:00 PM
