I am hoping you can help with a swap in a 94 4runner 3vze. We are doing a 5vze and have the motor in and running and the truck will drive but the transmission will not shift gears and we think it is due to wiring. Do you have and diagrams you can share to help or anything? It is a 98 5vze and 98 ecu 4runner ecu 4x4 with a the stock a340h transmission. I made a jumper harness from the body harness to 5vze exh.
I have downloaded the pdf and I am going to go back through but does anyone know what exact pins and connectors control this?
