3.4 swap begins
Old Jul 24, 2010 | 07:47 PM
INFINITY's Avatar
Originally Posted by RobD
Do you have to smog where you are? I never bothered with any of the EVAP system and have been running fine.
no, no emissions here. good to hear you are running ok. does it throw a cel or any other side effects?
also i have elvot's thread bookmarked.
Old Jul 25, 2010 | 08:17 PM
RobD's Avatar
For me to have a CEL, I'd actually have to have the light wired
Never got around to that part of the swap.
Been running fine for almost 3 years (August 20th-ish 2007) with over 114 500 kms (71,500 miles) on it, and no problems.
Old Jul 25, 2010 | 08:40 PM
vital22re's Avatar
totally a bro
i've... i've already gone to the to the forced induction side on my swap.
Old Jul 26, 2010 | 03:39 PM
INFINITY's Avatar
sure would be nice.
Old Jul 27, 2010 | 11:21 AM
  #25
INFINITY's Avatar
put the new timing belt, water pump, thermostat on last night. tonight going to work on finishing the wiring and welding up the rad support and front frame sections (cracks and separation from over time of driving mainly dirt roads).
Old Jul 27, 2010 | 11:28 AM
  #26
vital22re's Avatar
totally a bro
I taped my diagrams together like you did. makes it a lot easier!
Old Jul 30, 2010 | 04:56 PM
  #27
INFINITY's Avatar
doing the oil pan/ pickup/dipstick/rear main/oil pressure gauge sender now.
for the alt lower bracket i used the factory 3.0 one. then for my oil pressure sending unit i used a 90 deg brass elbow then screwed it on so that it would not interfere with the alt bracket.
wiring is mostly done with exception for the small stuff, road lights, e-fan, dash switches, etc...
hopefully it starts up and runs good. down to 6 nights to finish before we need the truck for bear season (with hounds) here.
Old Aug 3, 2010 | 09:49 PM
  #28
INFINITY's Avatar
well down to 2 days left. motor is in and runs. need to do exh, put bed on, hood scoop, and other small things. but SHE IS ALIVE!!
time for sleep. i will post up more picts when i have some time.
for the power steering pressure hose i did use the tacoma one. i have a small hand held tubing bender and just straightened and rebent.
Old Aug 4, 2010 | 11:12 AM
  #29
jskijoe's Avatar
big CONGRATS!! That's a great feeling. I look forward to hearing about the first drive
Old Aug 6, 2010 | 09:25 PM
  #30
INFINITY's Avatar
done and done. will post up some picts later on. right now it works BUT has a high idle when warm? any ideas.
Old Aug 6, 2010 | 11:22 PM
  #31
vital22re's Avatar
totally a bro
check your throttle cable and make sure its not too tight. I had to bend the braket a bit to get the cable loose.
Old Aug 10, 2010 | 03:57 PM
  #32
INFINITY's Avatar
the idle went down, i had the heater core closed and got a air bubble. idle is great now and has tons of power.
more picts to come
Old Feb 8, 2011 | 03:43 PM
  #33
INFINITY's Avatar
a recent one while on a lion hunt last month.
Old Feb 12, 2011 | 10:14 PM
  #34
YOTAARMYGUY's Avatar
Lion hunt?? In Arizona? Or is a "Lion hunt" something other than what I am thinking it is? What does your oil pressure gauge read after it has warmed up??
P.S. She is looking great!!!
Old Feb 16, 2011 | 06:41 PM
  #35
INFINITY's Avatar
yea mountain lion (bear hunting with dogs here in az is only in the fall). cant remember what the oil pressure reads when it is at operating temp but i will try to remember to make a mental note of it and re-post it later.
Old Feb 16, 2011 | 06:42 PM
  #36
INFINITY's Avatar
oh yea dont know if anyone noticed that i cut the top of the T off of the toyota emblem. i like it, it looks like a bull head.
Old May 2, 2011 | 08:54 PM
  #37
INFINITY's Avatar
sorry been awhile. using the 94 gauges and 3.0 sending unit on the 3.4 block the gauge warmed up idling reads between the low and first slack mark.
Old May 3, 2011 | 08:40 AM
  #38
hamish_18's Avatar
oh good. soo does mine lol. I wish the gauge would show a little more pressure, but oh well.
Old May 17, 2011 | 06:10 PM
  #39
INFINITY's Avatar
new bumper. not bad for the first time building a tube bumper and using a bender.
Flying91
45
Apr 11, 2024 04:39 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
93toyoguy
Aug 2, 2015 07:41 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
94whiterunner
Jul 12, 2015 07:15 PM
