3.4 swap
https://www.yotatech.com/forums/f160.../#post52163785
looks like 3.4 starter, flywheel, and clutch with a 3.0 throw-out bearing
Or you can run all 3.0 stuff (flywheel, clutch, starter, throw-out bearing) Pilot bearing I think is the exact same. Be aware though that the 3.4 clutch disk and pressure plate have a bigger surface area therefore better hold. You can use an aftermarket "performance" clutch to make up for it.
If using the 3.4 starter, you will need to drill out the threads on one of the bolt holes on the starter as it bolts on with both bolts from the transmission side. The 3.0 starter matches the transmission.
91slowrunner
May 21, 2007 09:11 PM
Justin311
Apr 14, 2006 11:18 PM
